Remove Grout From Allure Vinyl Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 08-02-2010, 01:14 AM   #1
Unhappy
remove grout from Allure vinyl flooring
What is the best product to use when removing dried grout from the Allure vinyl flooring? I know now after the fact this was a BIG DO NOT.. I only used grout because I noticed a few small gaps in between some of the vinyl strips once the floor was done. Now I have dried grout on the tiles and not sure have to remove the grout without damaging the tiles.
abkjr is offline   Reply With Quote
Old 08-02-2010, 09:50 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
You probably should contact HD and see if they have any ideas or contact the maker or Metroflor the distributor.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 08-02-2010, 06:21 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Try heating it. Use a heat gun.
XXX
Remove tile grout ninghai Flooring 6 06-06-2010 09:51 PM
Trafficmaster Allure Commercial Confetti Dark Grey Vinyl Flooring (24 Sq. Ft. Per Cas bennyjets Flooring 3 08-09-2009 10:50 PM
Grout question poolecw Flooring 11 10-29-2008 07:32 PM
asbestos problem with vinyl flooring darsunt Flooring 6 08-31-2007 01:47 PM
Can I cover old cracked vinyl flooring with lauan and new vinyl? MikeC. Flooring 4 03-12-2007 05:20 AM
