Old 12-30-2009, 10:20 PM   #1
remove gleued carpet from concrete floor
I am removing wool carpet from a concrete floor which has been glued down, only been layed for about 6 months, there is no under lay, how is the best way to remove the carpet without damage. HELP ME!!!!!
nkcnf is offline   Reply With Quote
Old 12-30-2009, 11:31 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Without damaging what?
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 12-31-2009, 12:18 AM   #3
The carpet was layed about 6 months in an office block and has never been walked on or used. new owner want to replace this carpet. The carpet has been glued to a concret floor and I wanted to know how hard this would be to pull up as I want to use the carpet again without damaging the carpet. I don't know if it has been glued just around the edges or all underneath.
Old 12-31-2009, 01:14 AM   #4
Tack strips around the edges? Probably not glued too securely - maybe a bead running around under the center areas. No way to really know till you get in there pulling it up.
I have a fairly heavy 6" wide scraper on a long handle - I would start pulling up the carpet and using the scraper as needed to work the glued areas loose and work my way across the floor.
Old 12-31-2009, 01:29 AM   #5
Why don't you try an oscillating tool like the Dremel Multi-Max? it comes with an attachment that's used for removing tile, and might work. Harbor Freight sells a Chinese made tool like this for $35. It's called a "Multifunction Power Tool": http://www.harborfreight.com/cpi/cta...emnumber=67256
I have one, and it's super useful for all kinds of projects. Not sure if it'll work on carpet, but might be your best option to try. Go slow, and make sure it's not damaging the carpet as you pull it off.
TitaniumVT is offline   Reply With Quote
Old 12-31-2009, 01:32 AM   #6
Thankyou, I will be picking up next week so I will have to get myself a scraper and I will let you know it all goes.
Old 12-31-2009, 01:49 AM   #7
Hmmm and a power tool too!! better to be prepared!!
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
getting rid of carpet > concrete floor > polish or stain? johnlvs2run Flooring 24 11-23-2010 11:31 PM
How to cut a hole in a concrete floor slab tomseeley General Discussion 7 06-10-2009 03:32 PM
Finishing Basement, carpet install order? tigerbalm2424 Flooring 33 07-24-2008 09:35 AM
