Old 12-14-2011, 11:18 AM   #31
Remove floor tile set in 3/4" concrete
Didn't even think about mentioning the stairs earlier - those were mudded originally in the same way as the floor and we tore those out as well last weekend. We figured that if they had lasted 30 years in great shape like the floor that we'd just do those the same way again as well. Only time can tell at this point, 'cause they're in now!
Thanks again for all of the help & advice!!!!http://www.diychatroom.com/images/smilies/thumbup.gif
Dmeyr is offline   Reply With Quote
Old 12-14-2011, 12:07 PM   #32
Tileguy
Bud Cline's Avatar
If the stairs were built in a manner that they have survived for that long previously then you should be okay. Stairs however can be a particular problem and don't always survive the abuse of everyday use.
concrete drive and walk 7echo Landscaping & Lawn Care 12 04-22-2011 06:03 PM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 06:42 AM
(Need Advice) Remove 1/2" galvanized NPT pipe from END VillageIdiot Plumbing 5 02-15-2010 07:31 AM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
