Remove Floor Joists And Crawl Space - Flooring - DIY Chatroom Home Improvement Forum
Old 03-26-2010, 12:31 PM   #1
Remove floor joists and crawl space
Hi all,
We bought an older home, and realized the floor joists were not in that great of shape when we pulled up the wood floors that were not in that great of shape (in living room and one bedroom). There is a crawl space, but nothing runs in there anymore. We've thought about just removing the floor joists, bringing in dirt, and putting down a concrete floor. What would be the pros and cons to doing this? We would be eliminating the crawl space in these rooms.
Thanks,
Steve
archsteve is offline   Reply With Quote
Old 03-26-2010, 02:52 PM   #2
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
#1 you might want to add something back there
#2 it's going to take a lot more dirt than you think
#3 concrete is going to be difficult, expensive, and messy. You will likely have to pump it in.
#4 you will have to build a retaining wall complete with code compliant footers to keep the dirt under the concrete from spilling out
#5 your house is using the floor joists and removing them could be catastophic
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
The Following User Says Thank You to jcalvin For This Useful Post:
kwikfishron (03-26-2010)
Old 03-28-2010, 05:15 PM   #3
JCalvin, thanks for the good points. I think we will probably just fix up the joists, and add floors on them. I am assuming we can sister to most of the joints to even them out and make them safe for our floors.
Thanks.
Tags
concrete , crawl space , floor joists
Crawl Space Insulation skinny2 Building & Construction 10 12-12-2008 12:36 PM
thoughts on crawl space heating rtoni HVAC 3 09-30-2008 01:47 PM
Crawl Space - to vent or not? tomandlu Building & Construction 2 01-15-2008 08:23 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 09:15 PM
Screening the crawl space vents ziggy29 Building & Construction 2 11-29-2006 09:26 PM
