Remove Existing Hardwood Planks To Replace With Tread - Flooring - DIY Chatroom Home Improvement Forum
Old 01-15-2013, 03:29 PM   #1
Remove existing hardwood planks to replace with tread
Hi,
I have an upstairs balcony whose floor has already been laid. The hardwood is parallel to and against the edge of the supporting wall. Previously there were wood balusters attached to shoe rail tacked onto the floor, and the edge of the floor over the wall was hidden by baseboard. (Hopefully the photos below help make sense of all this.)
I'm putting in iron balusters and what I'd like to have in the end is a stained landing tread underneath them, flush with the floor. This would mean cutting out existing flooring — three plank's width — to lay the tread in.
Is this possible?
Thanks for any advice.
Remove existing hardwood planks to replace with tread-img_1636.jpg   Remove existing hardwood planks to replace with tread-img_1637.jpg
roger wilco is offline   Reply With Quote
Old 01-15-2013, 10:56 PM   #2
chitownken's Avatar
Rewards Points: 510
Looks like you can pry it up. Just be really careful with the third row so that you don't crack the row that is going to stay when you pry it out The tongue goes into the groove in the fourth row and you can easily crack it.
chitownken is offline   Reply With Quote
Old 01-16-2013, 04:28 PM   #3
Rewards Points: 264
I am assuming you want to add a stair nosing around the perimeter? If so, I would tack something to the floor to use as a guide and cut out the flooring with a circular saw. Then take a router and route a groove into the flooring, then take a piece of spline add it to the groove. This will lock the new nosing into the floors. Then glue and nail in the new nosing. Looks like you will probably need a molding under the nosing as well to hide the drywall. So I would account for this when figuring out where the nosing will sit to be sure you leave enough overhang. Hope this makes sense.
Awoodfloorguy is offline   Reply With Quote
Old 01-16-2013, 10:42 PM   #4
This was my original plan which I was first talked out of…thinking it'd be too tricky to cut a good enough line across and it'd leave too little of a plank left over to butt against the new tread.
Now I'm thinking I could pry up the first three planks (1.5") and use a 5.5" landing tread. I'd have to rip the tread to get a 4.5" floor width which would leave an inch overhang.
I don't think this would be too difficult but my lumber guy is trying to talk me out of it.
Old 01-17-2013, 12:04 AM   #5
Rewards Points: 264
On the ones that run parallel if this does in fact fall in like that, you could just remove the boards. On the other ends, you would need probably need to cut it. But at least these are the shorter cuts.
Old 01-17-2013, 08:19 PM   #6
chitownken's Avatar
Rewards Points: 510
You can get 8 foot aluminum straight edges and use double stick tape to hold it down to the floor to use as a saw guide if you have to cut the floor. Biggest concern will be hitting the fasteners when you cut.
Old 01-21-2013, 12:33 AM   #7
Did the cut a few days ago, fitting the tread now.
The parallel cut was super-easy — just pried up the first three planks. The tread I'm using isn't grooved so I was planning on chiseling the tongue off of the boards (i.e., I wasn't too careful to maintain the tongue), but it turns out keeping the tongue intact was simple with a little patience.
The perpendicular cut on the short end was a pain. The circular saw didn't have room to cut the entire length so I tacked a straight-edge to do as much as I could, ripped as much as possible parallel, and used a chisel for the rest. (I'm sure there's a better tool for the job but I don't own it.) Came out pretty nice, although I need to square the cut a tad to get the tread super-flush. Not sure how I'm going to do this yet. (sand?)
Thanks for the tips.
PL premium on hardwood flooring - how to remove? annette.arial@bell.ca Flooring 5 10-18-2013 06:32 PM
Gap between hardwood floor planks sundh Flooring 4 10-03-2011 10:28 AM
Replace hardwood stair treads acerunner Carpentry 15 02-21-2011 01:06 PM
Remove hardwood for tile headcrash0101 Flooring 5 06-23-2008 03:21 PM
Hardwood has a subfloor on top that I would like to remove capslock Flooring 3 04-01-2008 11:27 AM
