Old 10-31-2006, 12:51 PM   #1
Default Remove concrete subfloor in bathroom?
I've just moved into a 1929 home that has a concrete subfloor in the 2nd floor bathroom. There is a leak somewhere from the supply or drain piping in that bathroom, leaking onto the dining room ceiling below. In addition, I want to reroute some plumbing, as I'm putting in a clawfoot tub. Access to the pipes from the dining room ceiling is not feasible, since it's an artistic sculptured ceiling. I've started tearing up a portion of the concrete subfloor to get to the pipes, and am contemplating removing all of the concrete subfloor. In that case, I would rebuild a standard subfloor for ceramic tile (plywood subfloor, backer board, etc.). I know it's a huge job, but has anybody done this? Any recommendations or major concerns?
dascreek is offline   Reply With Quote
Old 11-14-2006, 06:58 AM   #2
Home Maintenance Engineer
manoloK's Avatar
It should be OK as long as this concrete floor is an under layer only.
In some countries, like in Spain, we build the house structure with concrete. However, if that were the case you wouldn't have the pipes running through the concrete floors, they'd be running in the walls instead.
So, if this is only a layer of concrete over your house structure that was laid for flooring purposes, it will be fine. It'll be simply hard work to get rid of the whole concrete. If this is the case the concrete layer it'll be only an inch or two.
Otherwise bring in a builder to have a look and give you the right directions, you don't want to mess with the house structure.
manoloK is offline   Reply With Quote
Old 02-16-2007, 12:24 PM   #3
Default Done with the concrete floor removal
Well, it took a while, but I've removed the concrete subfloor from the bathroom. The tile was set in a layer of concerete about 3/4" thick, and that layer was on top of another layer of coarser concrete. All total, there was about 2.5 - 3" of concrete on the floor. Underneath were 1/2" planks between the joists, set on nailer boards. They had grooved the tops of the joists to form a well for the concrete, so the tops were triangular. I can't rest the new plywood subfloor on those, so I'll be screwing in sister joists to those. It was a major, time-consuming, dirty job, and I wouldn't recommend it to anybody who didn't have to do it. I've now got the new plumbing roughed in, and the bathroom is back to nearly functional. BTW, same story with the walls ... tile set on a layer of concrete over a concrete/metal lath. Those are also all done, and I'm putting up greenboard.
Old 02-16-2007, 12:56 PM   #4
manoloK's Avatar
Hi dascreek,
Nobody said it'd be easy
Good job, well done.
Manuel :p
Old 02-17-2007, 12:52 AM   #5
Sounds like you are on the right path dascreek! Not sure if you were able to use anything from this site or not but I am sure someone will be able to use you experience if they have the same problem. Great job and keep us up to date!!
Also thanks for you input manolok!!
daman3178 is offline   Reply With Quote
Old 07-05-2008, 05:35 AM   #6
Okay, how can I decorate a basement apartment? Adding to my troubles-we have wood walls in all but the bathroom and kitchen! Since we rent this apartment, and are on a budget, major renovations are out of the question for the most part. It's kind of drab and dismal...I would love track lighting but know the landlord would never in a million years pay to have it installed.
tiffanym is offline   Reply With Quote
More On This Topic
We've mixed up some more concrete and we're just in the process of finishing off this job here. Put some back in the bucket, here. Once this dries, in a day or so, we can come in and lay our tile and that will finish up our floor. The reason that I'm... Read More »
When undertaking a home improvement project, you need to know how much concrete you will need and what kind is best for your project. Determining the right amount and kind of concrete you need will save you money and trouble in the long run. Read on to... Read More »
Now we’re going to talk a little bit about the recycled products. The terrazzo type countertop material is usually a ¼ inch, you can even order it thicker than the ¼ inch, ½ inch, and it does have to have underlayment so it doesn... Read More »
We finished our drywall. We put our first coat on yesterday, of drywall mud to seal up all the joints and the nail holes. This morning I came in and finished the top layer of the drywall. I used a twelve in knife which makes a nice wide band here, makes... Read More »
One of the best changes or upgrades you can make to your home is adding or changing the tile in your kitchen or bathroom. Before you can begin this type of upgrade, you must first buy your tile. Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
