Remove Carpet From Wooden Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 11-05-2011, 07:39 PM   #1
Remove Carpet from Wooden Floor
Hi,
I would like to know step by step instructions to remove carpet from wooden floor.
Thanks,
DSHA
DSHA is offline   Reply With Quote
Old 11-05-2011, 07:42 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Gonna need to know more than that DSHA.
Is the carpet glued down?
If not, grab ahold of it and pull it out. What else can I say?
Old 11-07-2011, 03:45 PM   #3
I wish it was not glued but it seems that it is. So it means that I would need to scrape it or cut into small pieces
Old 11-07-2011, 04:02 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Okay...what is the carpet backing made of. Is it a foam backing or what looks like just the bare carpet weaving?
Glued-down carpet can be a pain to remove. You are correct. The way to remove it is to cut it in strips maybe 12-16 inches wide, get a pliers, and go for it. The width of the workable strips depends on how much the carpet is fighting back. Some is easy to remove - some not.
Butting new floor carpet to temporary old stair carpet gordongroom Flooring 1 03-23-2011 05:04 PM
Hydronic in floor heat with carpet Jacobs.sr22 Flooring 1 01-17-2011 11:31 PM
How to Soundproof the Wooden Floor? loomb8 Flooring 2 11-20-2008 12:23 PM
How to Stop the Wooden Floor from Creaking? loomb8 General DIY Discussions 2 11-20-2008 10:37 AM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
