Old 12-16-2007, 04:38 PM   #1
Remove baseboards before carpet installation?
I am going to be having new carpet installed in 4 bedrooms. Should I remove the baseboards before installation? I am also thinking about replacing with some nicer baseboards. Do the installers need baseboard in place in order to install the carpet? If so, how high should I place the new baseboard? Thanks.
digexpressions is offline   Reply With Quote
Old 12-16-2007, 04:39 PM   #2
Carpet is installed up against the baseboard, so I'd put your new stuff in right down on the subfloor before the installers come.
NateHanson is offline   Reply With Quote
Old 12-16-2007, 07:28 PM   #3
Tileguy
JazMan's Avatar
Base is installed about 3/8" off the subfloor, not on it.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 12-16-2007, 08:47 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Leave your baseboard where it is. You're allset.
- Build Well -
Old 12-16-2007, 08:59 PM   #5
Oldguy
Rehabber's Avatar
The baseboard for carpeted floor may be installed either on the floor or up to 1/4" above the floor. It's just a personal preference.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 12-16-2007, 09:13 PM   #6
Makes for a much neater looking install if the base is up off the floor.
If it were concrete, you would have to raise it
mike costello is offline   Reply With Quote
Old 12-17-2007, 10:46 AM   #7
I haven't seen that in either of my houses - both have baseboards on the floor - but I suppose I can see the sense in the alternative way.
blackening on carpet around baseboards ejlog Flooring 12 07-09-2008 10:49 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 09:26 PM
Carpet Nightmare The Nomad Remodeling 3 09-30-2007 09:25 PM
Need to remove baseboards that are glued and nailed recklessrick Painting 7 10-14-2005 06:20 PM
