Removal Of Old Mortar From Surface Of Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 10-10-2012, 07:13 PM   #1
Removal of old mortar from surface of tile
I am remodeling a bathroom in a 100 year old house. The bathroom was remodeled approximately 50 years ago. Ceramic tile was laid over the original tile, a beautiful one inch octagon shaped tile. The second layer is coming up without damage to the original and I would like to restore the original. However, there are considerable amounts of of very hard mortar remaining. Is there any way to remove this mortar without damaging the original tile surface?
Edmon is offline   Reply With Quote
Old 10-10-2012, 08:28 PM   #2
Rewards Points: 13,740
No way that I've seen, heard of or tryed and worked.
Old 10-11-2012, 04:13 AM   #3
DIY staff
Rewards Points: 7,174
Sand it off with 220 grit--
The old porcelain mat finished tiles will not be harmed---try a spot.
Any chemical that will remove the thinset will also loosen the antique tile.
Edmon (10-11-2012)
Old 10-11-2012, 10:28 AM   #4
Thanks. My first thought was to try to sand it, but feared scratching the tile. There is a hidden area I can experiment on.
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
exterior mortar mix for tile tabletop candoo Building & Construction 0 05-04-2012 07:33 PM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 10:43 AM
Ceiling tile removal - how hard? mrs1885 Remodeling 1 01-07-2011 02:24 PM
concrete paint removal before tile installation SR996 Flooring 1 03-21-2009 07:31 PM
