Removable Tile For Accessability - Flooring - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 04:45 PM   #1
removable tile for accessability
Hi everyone, I am in the process of finishing my basement and am just about ready to do some floor tile. My issue is that in one particular location I have a access cover to a backflow proventor where I want to tile. It is very level and flush with the rest of the floor so I would have no issues going over it but don't believe it is the right thing to do. Is there a product or a process I should use to keep this accessable without having a loose piece of tile over top of the cap?
Any and all suggestions are appreciated!!
msukazman is offline   Reply With Quote
Old 10-04-2010, 05:45 PM   #2
Carpet tile
JCW355 is offline   Reply With Quote
Old 10-04-2010, 06:39 PM   #3
firehawkmph's Avatar
Rewards Points: 1,922
Ms,
I am assuming you are talking about ceramic or porcelain tile. If you lay out your floor so one tile will cover your b/f preventor, you could just put some silicone sealer on the bottom, enough to have it not wiggle when it sets up, and then just use matching caulk instead of grout around it. You should be able to remove it easily in the future by just slicing the caulk with a utility knife and gently prying up the tile. Keep a couple of spares in case it would crack.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
