Remov PL Premium - Flooring - DIY Chatroom Home Improvement Forum
Old 12-03-2011, 07:53 AM   #1
Remov PL Premium
There are several spots of PL Premioum on a new birch floor. How do we remove the glue
SVernon is offline   Reply With Quote
Old 12-03-2011, 08:28 AM   #2
Rewards Points: 1,644
I would imagine you'd have to carefully scrape it off and then sand. Is this on a finished floor?
I doubt there is a solvent that would remove it and not affect the floor finish.
From the PL Premium site:
How do I remove LePage® PL® Premium after it has cured? LePage® PL® Premium is very difficult to remove once it is cured. Therefore, it is extremely important to clean up any spills of PL® Premium before it has a chance to cure. A cloth dampened with mineral spirits will help to remove any uncured PL® Premium from surfaces and tools. Once PL® Premium has cured however, it can only be removed by mechanical abrasion (i.e. scraping or sanding). Soaking the area in LePage® Poly® Super Strippa first will help in softening the adhesive however this will cause damage to any finished surfaces. Test area before use for compatibility.
bob22 is offline   Reply With Quote
Thinking of Behr Premium Plus deck/fence stain - good? curls00 Painting 77 07-31-2012 04:36 PM
Olympic Premium Flat and Semi-Gloss Ultra White fozzie Painting 15 12-07-2009 08:20 PM
Behr Premium Plus Ultra beachnik Painting 2 06-15-2009 04:36 AM
tiling with PL premium tonia Tiling, ceramics, marble 5 05-14-2009 08:23 AM
Storing PL Premium construction adhesive Nestor_Kelebay General DIY Discussions 14 12-19-2008 07:03 AM
