Remodeled Home With Extreme Buckling Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 07-27-2010, 11:38 PM   #1
Question
remodeled home with extreme buckling floors
The house was built about 1955 and completely remodeled and has wooden floors that appear glued. The floor was just fine until about 2 months ago. We lave lived there 18 month's. Three of the rooms have 3 to 5 inches of buckling. We have had rats, roaches, and other critters come through the cracks. What could have caused this extreme buckling. The insurance adjuster said that they would not cover the damage due to inside unit having a pipe that runs outside and constantly drips. This caused the house to buckle. Could this have happened in within two moth period?
Any information is appreciated.
Rico
rico worker is offline   Reply With Quote
Old 07-28-2010, 12:12 AM   #2
Registered User
Rewards Points: 4,936
Pictures would be helpful, and more info about the water source: http://www.woodfloorsonline.com/tech...oodwater1.html
Be safe, Gary
Old 07-28-2010, 12:44 AM   #3
buckling floor photo
[IMG]file:///C:/Documents%20and%20Settings/Guadalupe%20Sanchez.PC430180398780.001/My%20Documents/My%20Pictures/rico%20photo/100_1847.JPG[/IMG]Hello,
Here are a few photos. Do you think this white pipe that is not connected to any underground piping could cause the damage to floors by seeping under the house and causing the damage i have shown you? The pipe leaks out water from the unit inside.
Rico
remodeled home with extreme buckling floors-100_1853.jpg   remodeled home with extreme buckling floors-100_1850.jpg   remodeled home with extreme buckling floors-100_1881.jpg   remodeled home with extreme buckling floors-100_1860.jpg   remodeled home with extreme buckling floors-100_1864.jpg
Old 07-28-2010, 07:14 AM   #4
DIY staff
Rewards Points: 7,174
Severe damage like that is usually caused by a leak directly under the wood.
The high humidity in your crawl space could do it,but I think you need to look for the usual suspects--
The most common household leaks: Dish washer,icemaker,dripping shutoffs under sinks--toilet wax ring-
cloths washer--nail through a pipe--
You crawl space looks like a dangerous place---I saw Romex on the earth--deadly.
If you can safely enter that--crawl around and look up at the bottom or the flooring--I bet you find a wet spot--If so ,find the source --take pictures and call the insurance guy back.--Mike--
Old 07-28-2010, 08:13 AM   #5
Rewards Points: 184
I agree, it must have water directly touching it, especially since most of the boards are fine.
abefroman is offline   Reply With Quote
Old 07-28-2010, 02:54 PM   #6
Registered User
Check the nails in the wood planks. It may be the installer used finish nails for those last few boards when he finished the run which were nailed through the tongue normally. When he got to the wall, his mechanical nailer was too big for the limited space--- had to face nail with finish nails- normal procedure. The other pic, check for a spline added on each side to change direction of the t&g so he could install both directions from the center layout. With lack of under-floor insulation and a vapor retarder, it could easily absorb the moisture to buckle it, especially if only face nailed. Those would be the first boards to move. Lack of enough expansion gap at the wall, under the 1/4" shoe molding, would cause it to lift.
1. Locate the water source from the drain pipe...... Let us know.
2. Is there tar paper under the flooring?
Be safe, Gary
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
Insulateing a Home Rifeman Building & Construction 9 08-31-2007 05:28 PM
Unlevel floors in new home sbland Flooring 3 02-11-2006 05:05 PM
Home Improvement/Remodeling Contractor Website Possibility? newigal General DIY Discussions 6 01-03-2006 10:38 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
