Old 05-02-2007, 01:19 PM   #1
Remodel - Subfloor, then what?
Sheetrock, Durock, Floor Tile? or Install the complete floor with the sheetrock on top?
Jeekinz is offline   Reply With Quote
Old 05-02-2007, 03:19 PM   #2
Tileguy
JazMan's Avatar
You aren't expecting an answer to a one line question like that are you? If you can't be bothered to fully explain your project and then ask a question or two, why would you think any of the pros here would bother to give you free advice that does not benefit us one bit?
YICKS!!
Jaz
Old 05-02-2007, 04:41 PM   #3
I installed the sub floor, does the durock and tile go down before the sheetrock goes up? or do I install the sheetrock then but the foor against it?
Old 05-02-2007, 04:46 PM   #4
YICKS!!
Jaz
Old 05-02-2007, 05:30 PM   #5
Hang and finish the drywall first then rock then tile. Why would you want to mess up or cover up your floor job before the walls are done?
Were you a job super in a previous life?
Zero Punch is offline   Reply With Quote
Old 05-03-2007, 12:02 AM   #6
usually sheetrock is held above the floor by about an inch. The gap is covered by base moulding.....you can do it in whatever order you want, but I agree that it is better to hang, tape and texture the sheetrock first....i would even paint first.
send_it_all is offline   Reply With Quote
HVAC plans for remodel wease HVAC 3 03-23-2011 11:47 AM
Bath remodel wiring Nhrafan Electrical 14 03-23-2007 06:53 PM
Master Bath Shower Remodel with images MattCoops Remodeling 4 01-10-2007 04:16 PM
Electical planning for remodel wease Electrical 10 12-09-2006 11:36 AM
Do you have to pull new wires for remodel? wease Electrical 1 12-07-2006 02:49 PM
