-   -   Remodel - Subfloor, then what? (http://www.diychatroom.com/f5/remodel-subfloor-then-what-8164/)
Jeekinz 05-02-2007 01:19 PM
Sheetrock, Durock, Floor Tile? or Install the complete floor with the sheetrock on top?
JazMan 05-02-2007 03:19 PM
You aren't expecting an answer to a one line question like that are you? If you can't be bothered to fully explain your project and then ask a question or two, why would you think any of the pros here would bother to give you free advice that does not benefit us one bit?:no:
YICKS!! :censored:
Jaz
Jeekinz 05-02-2007 04:41 PM
I installed the sub floor, does the durock and tile go down before the sheetrock goes up? or do I install the sheetrock then but the foor against it?:huh:
Jeekinz 05-02-2007 04:46 PM
YICKS!! :censored:
Jaz
:thumbsup:
Zero Punch 05-02-2007 05:30 PM
Hang and finish the drywall first then rock then tile. Why would you want to mess up or cover up your floor job before the walls are done?
Were you a job super in a previous life? :confused1:
send_it_all 05-03-2007 12:02 AM
usually sheetrock is held above the floor by about an inch. The gap is covered by base moulding.....you can do it in whatever order you want, but I agree that it is better to hang, tape and texture the sheetrock first....i would even paint first.
