Relaying Small Section Of Pulled Up Carpet - Flooring - DIY Chatroom Home Improvement Forum
Old 12-06-2010, 10:10 AM   #1
Rewards Points: 101
Relaying small section of pulled up carpet
This comes an earlier post of mine where pulled up some carpet to investigate a wet spot in the basement (but I believe it was just a spill). I pulled about 13 feet of carpet about 18 inches from the wall. The basement is actually longer than 13 feet but there is a small 18 inch wall that sitcks out. If I do this myself, what are some useful tips. What I have read usually discusses a new install and uses a kicker along the edges, followed by using a stretcher, and finally then finally cutting and tucking. Since this is just laying it back down, would the recommended procedure still be knee kicker followed by stretcher and then tuck, or just the kicker, or just the stretcher? I've heard the stretcher can easily ruin and tear the carpet if you are not careful.
I finished the basement myself with some help from my dad (a former builder) so I am typically able to do alot myself with some careful preparation, and a local rental place has both a kicker and a stretcher.
wvphysics is offline   Reply With Quote
Old 12-06-2010, 12:01 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
The stretcher should be all you need.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The age-old question: cats and carpet sbattisti Flooring 7 03-19-2011 02:39 PM
torch down small roof section ernst Roofing/Siding 8 07-10-2009 05:04 PM
carpet install problem plummcrazy Flooring 1 04-15-2008 01:42 AM
glued down carpet...can I cheat? Dusty Flooring 3 10-10-2006 06:18 PM
