Reinforcing Squeaky Wood Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 11-14-2008, 07:19 PM   #1
jelly's Avatar
Rewards Points: 330
My first floor hardwood is squeaky but before I close up the ceiling in the basement, I would like to remove some of the squeaks.
Can I simply jam a shim between the floor joist and the sub floor as a quick fix? Not looking to spend a lot of cash on the project.
jelly is online now   Reply With Quote
Old 11-14-2008, 07:34 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
How do you know that its the sub floor rubbing on the floor joists and not the hardwood floor rubbing on the sub floor? if its the floor joists what i do with great results is run a bead of PL Premium sub floor adhesive.along both sides of the floor joist up against the sub floor.
or if its the hardwood floor rubbing against the sub floor I locate the squeak from below and install a 1-1/4" drywall screw from the bottom of the sub floor up into the bottom of the hardwood floor until the squeak stops. 1-1/4" only if there is 3/4 + 3/4 hardwood. Good luck BOB
Old 11-14-2008, 10:19 PM   #3
jelly's Avatar
Rewards Points: 330
Hi bob, all i did was push up on the sub floor next to the joist with my fist and the squeak stopped so I thought if i put a shim in there it would help.
I will consider a couple drywall screws and/or a bead liquid nail. Thanks
Old 11-15-2008, 06:38 AM   #4
buletbob's Avatar
NOT LIQUID NAILS! USE PL Premium construction adhesive, it will harden not like liquid nails, put something that as some weight to it on top of the floor then go below and glue both sides of the floor beam.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Washing my wood floors J187 Flooring 1 11-14-2006 11:13 PM
