Regular Roofing Asphalt Paper Under 3/4" Wood Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-10-2007, 08:54 PM   #1
zel
Rewards Points: 150
Send a message via AIM to zel
regular roofing asphalt paper under 3/4" wood floor?
I ordered my 3/4" Brazillian Redwood back in April, it finally came in yesterday. We are installing in a 2nd floor bedroom on 3/4" plywood over 2' span joists, perpendicular of course. The spec sheet says "laminated rosin paper or #15 builders felt (tarpaper) may be used to reduce movement and retard moisture, etc."
Just wondering if this is typical asphalt roofing paper? I happen to have a roll and a half of this from redoing the exterior wall. TIA.
zel is offline   Reply With Quote
Old 07-10-2007, 09:37 PM   #2
remodeling pro
#15 builders felt is the same thing as "tar paper". Rosin paper is a very thick paper, about the thickness of poster board and kind of terra cotta in color whenever I have seen it, and I am not sure what it is impregnated with.
troubleseeker is offline   Reply With Quote
Old 07-10-2007, 09:51 PM   #3
zel
Rewards Points: 150
Do you think it is a good idea to use this under the wood to dull some noise, if nothing else? Thanks for the resonse.
Old 07-12-2007, 10:19 PM   #4
remodeling pro
Absolutely, you want a barrrier between the two wood layers to help prevent squeeks from movement.
Old 07-12-2007, 11:02 PM   #5
zel
Rewards Points: 150
Thank you. I'm hoping to begin by next weekend.
Installing Laminate Flooring over Wood Laminate Floor bantammom Flooring 7 05-27-2011 03:34 PM
Wood floor help/suggestions bigboyjoel Flooring 18 12-31-2008 12:02 PM
Wood floor or carpet? darsunt Flooring 9 08-03-2007 11:12 PM
Leveling wood floor helpless handyman Building & Construction 1 10-17-2006 10:06 AM
Removing Linoleum backing paper from wood floors SatDoug Flooring 4 09-16-2006 11:00 PM
