reglueing ( ? ) existing flooring
i see u're in Atl... go to georgia Oak flooring on Jimmy Carter blvd and ask for epoxy shots....you also need the gun from them... The shots are two component and they come with a nozzle and the drill bit for it... all you need to do is drill a couple of holes in the affected area, pump maybe half a shot in each and stand on the spot for 2 minutes. then fill the hole with matching color putty, which the store also has...
and you're done... it holds 4ever....
Careful not to make a mess on the floor with the epoxy, cause it dries lightining fast and it's avery tough to remove.... have a clean rag close at all times....
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 50% down, 50% after all your complaints....
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. hardwood floors, To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
