Old 10-24-2011, 01:01 PM   #1
refinishing wooden stairs
I have very old wooden stairs that i want to refinish. i have used a stripper to remove the varnish the was on the edges but i am having trouble sanding down the area to remove the old stain. What grades of sandpaper should i be using and will i be able to get the stain out to be able to restain?
kellyjo is offline   Reply With Quote
Old 10-24-2011, 09:55 PM   #2
sdsester's Avatar
It is unlikely you will be able to get the stain out of the grain. You can try sanding down to the depth of the stain penetration but you could end up chewing your stairs to an unacceptable thickness.
Options to try are staining and blending with a darker stain. You may find gel stains easier to control than liquids.
You can try bleaching the stain but try a small section first and don't get your hopes up too high.
sdsester is offline   Reply With Quote
wooden stairs on existing concrete stairs ThaboG Carpentry 7 08-06-2010 10:03 AM
Ideas for refinishing hardwood stairs?? RinSF Flooring 10 06-01-2010 04:25 AM
outdoor wooden covering stairs over old concrette stairs junior112208 Building & Construction 1 05-31-2010 10:46 PM
Refinishing Oak stairs dave0101 Carpentry 4 12-11-2009 04:06 PM
Help w/ refinishing hardwood stairs...!!! bujaly Carpentry 22 03-16-2009 03:05 PM
