Refinishing Wood Floor - Can I Sand Over Paper? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-16-2009, 09:55 PM   #1
Rewards Points: 162
Refinishing wood floor - can i sand over paper?
I've got some paper backing left over from the linoleum they had over it. I got up what I could with the scraper, but I'm at the point where it's starting to gouge the wood and won't take up much more paper. Will the rough grit sandpaper take care of what I have left?
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 08-17-2009, 05:54 AM   #2
If the glue they used to put down the linoleum is water based, you'll have no real problems. You'll know in short order, because if it's the bad glue, you'll clog even the coursest paper in very short order.
The biggest secret to sanding a floor is to let the paper do the work it's intended to do. 20 grit is for removing varnish, minor carpet backing or minor linoleum remnants. 36 or 40 grit is the actual work horse. It's job is to actually do the wood removal. 60, 80 & 100 grits are the finishing grits. Their job is to smooth the floor.
Couple options for dealing with the stuborn areas of linoleum. Heat gun & putty knife. He will reactivate the glue so you can just scrape it up with the putty knife. Another option, go to Lowes, or somewhere similar & buy a real good paint scraper. You're looking for one with replaceable carbide cutters.
Even if the sander does a good job of removing the linoleum remnants, there's a good chance you'll clog the edger paper. The 2 different rpm's cause different heat buildup with different materials. If you've got one of the options I mentioned above, you can overcome those clogging problems when you get there.
pinwheel45 is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
problem: Water on wood floor during refinishing HouseMgr Flooring 2 08-15-2009 10:19 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
