Refinishing Painted Hardwood Stairs - Flooring - DIY Chatroom Home Improvement Forum
Old 06-16-2012, 10:48 AM   #1
I am a newbie considering refinishing my painted hardwood steps. I believe the stairs are oak (based on the rest of the house) and they are painted dark brown with an ugly anti-slip rubber/metal runner the whole way up. How best would I go about refinishing and staining them? I have a small (5" ?) orbital disc sander but otherwise I am completely unprepared. Will a paint stripper get it down to a point where I can stain and skip the sanding? How difficult a project is sanding steps? What sanding tools do I need? Thanks in advance for your help.
jpfulton248 is offline   Reply With Quote
Old 06-18-2012, 01:50 PM   #2
If I were you I would consider renting an edge sander. You can find these at Home Depot or most other tool rental shops. You will also need a carbide scraper and a file to sharpen it. The scraper is for areas that the sander can not get. I would just start with a 24 grit sand paper, then go over them again with a 36, then again with 50, then again with 100.
RhodesHardwood is offline   Reply With Quote
Old 06-18-2012, 03:36 PM   #3
Okay... so don't use a chemical stripper first? Just start right in with sanding?
Old 06-18-2012, 03:39 PM   #4
We never use chemical strippers. However, they probably would help remove a lot of the paint. If you choose to do this first, you could just put on some of the stripper, let it sit for a bit then use a scraper to take off the majority of the paint. If you did this you could probably then start with a 36 grit sand paper.
Old 06-18-2012, 03:46 PM   #5
Okay. I'll consider the stripper option. And you think the edge sander is advisable as opposed to the cheap hand sander I have? To save myself some work I'm thinking about painting the risers white but if i do choose to restore down to wood, will the edge sander work there too or is there a different tool I should seek out?
Old 06-18-2012, 03:50 PM   #6
The edge sander will not work on the risers. For these you would need to use a palm sander and a scraper. The edge sander will save lots of time and labor, I do think it is a much better option. It will be well worth the 30-$40 rental fee.
Old 06-18-2012, 03:58 PM   #7
Duly noted... I'm a do-it-yourself-er at heart but have to admit I'm very intimidated by this project... I've never refinished a wood floor (yet). Oh, one more thing, what about the landings? Probably a total of about 50 sq ft in landings/floor that leads up to the stairs. Do I rent another tool for this area or try to use the edge sander for the whole thing?
Old 06-18-2012, 04:00 PM   #8
The edge sander will work just fine for the landings too. Just be sure to use the sanding progression I noted before. This will ensure that you get sanding marks out from the previous grit.
Stairs - Match Upstairs or Downstairs Hardwood? arubatan Flooring 1 09-22-2011 10:10 PM
Refinishing Painted Hardwood Floors Nivk Flooring 8 09-18-2011 07:16 AM
Hardwood floor refinishing questions....drying time/paint/furniture ?? simiesue Flooring 1 06-07-2011 10:56 PM
refinishing maple hardwood speedster1 Flooring 36 12-17-2009 07:18 AM
My Hardwood Floor Refinishing project roxksears General DIY Discussions 3 11-13-2009 06:43 PM
