Old 11-02-2009, 12:15 PM   #1
Question Refinishing hardwood floors in the winter?
Will I run into any problems trying to refinish floors in the winter? Reading online, I've noticed the polyurethane will need several days to dry. How will this work in a cold room with snow outside? Will I need to complete isolate the room from the rest of the house to do this?
Here's what we found once we pulled the 20 yr old carpet.
http://imgur.com/L3WHg.jpg
http://imgur.com/Ct8at.jpg
http://imgur.com/kIHYe.jpg
http://imgur.com/LDpAD.jpg
Also, my understanding is since this floor is unfinished, an orbital sander will do just fine. But what about room where they had an area rug in the center and painted around it? Is this where the drum sander comes in handy? (these are smaller bedrooms).
http://imgur.com/BiQEd.jpg
http://imgur.com/KygMy.jpg
http://imgur.com/gTyOe.jpg
Thanks.
HautingLu is offline   Reply With Quote
Old 11-02-2009, 08:17 PM   #2
What a nice opportunity! These floors will look wonderful when you're done.
Well, other than the room being chilly you shouldn't run into humidity problems. I'm assuming the home is normally heated, right?
I just finished last coat of poly today on my floor refinish project (My Hardwood Floor Refinishing project). I am so very pleased with the results!
I closed all the doors to bedrooms/baths and taped a plastic sheet over doorway to family room trying to keep the stink out of those rooms and prevent heat loss in those rooms as well. It was quite effective. I turned my heat off, opened windows and put fans in windows while I was applying the poly and 2-4 hours afterwards. So to answer your question - no you don't have to do that, but it will help.
If it were me, I'd use the orbital sander on ALL the floors. I don't think you need a drum sander unless you have real uneven floors, etc. I bet you'll be surprised at how great the orbital will work, even on the painted floors. You may have to use a few more sanding disks (36 grit) but I'm thinking it will work.
If you do the living room first using the orbital you could give it a spin on the painted floor to see if it will do the trick. If not, get the drum sander.
Me? I know my limitations and I could not handle the drum sander at this time... my body won't take that abuse. It about killed me 6 yrs ago and I'm not getting any younger!
Good luck on your project!
roxksears is offline   Reply With Quote
Old 11-03-2009, 08:34 AM   #3
Thanks for the info. I'm hoping the orbital sander will do the trick in all the rooms.
The big room has seperate heating from the rest of the house and separate doors. So I can turn the heat off, open the windows, and close the doors.
I just wanted to make sure that it wasn't like paint, where it had to be above a certain temperature to dry.
Also, when renting a drum/orbital sander, would Lowes or HD have extra sanding pads or am I stuck getting them from the rental?
Old 11-03-2009, 11:15 AM   #4
I've not seen them at HD or Lowe's in their sand paper area, but that doesn't mean they don't have them... just haven't seen them.
There are places other than the box stores or rental place to buy the drum sand paper -- google to find something near you.
More On This Topic
Ok. Now, before we start our actual project, I need to go over the sanders that I brought with me. First off, we have the orbital sander and then we have the random orbit sander. Now, they both sound very similar but they do two very different things... Read More »
Hi! My name is Jennifer and I have over 10 years of woodworking and furniture restiiration experice. Okay, now before we start actual product, I need to go over the sanders that I brought with me. Let's take a look at how to use the random orbit sander... Read More »
I'm Rob McManhon with Expert Village. We are going to do a demonstration on using a orbital sander here. I have 2x6 and we will work on this side right here. The thing about the random orbital sander is that you can direct it much more on where you want... Read More »
I'm Rob McManhon with Expert Village. There is different types of sand papers as well. There is the belt for the belt sander. For the random orbit or the disk sander there is this type which is a hook and loop it is basically Velcro and its pad has the... Read More »
How to Use an Edge Sander
How to Use an Edge Sander by Expert Village
Okay, I'm going to show you how an edge sander works. Okay it's a rather large tool, it's a disk sander more or less the disk spins around on here, you can put a big heavy grit on it and then go down to a finer grit, but it has a plate that moves around... Read More »
Refinishing hardwood floors Daniel048225 Flooring 3 09-26-2009 10:31 AM
refinishing hardwood floors that have particle board over them skullface Flooring 3 06-02-2009 07:52 AM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 01:56 PM
Refinishing Hardwood floors ponch37300 Flooring 2 11-02-2008 06:08 PM
Refinishing Hardwood Floors Kyle Flooring 4 11-17-2007 01:08 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
