Old 05-31-2009, 07:07 PM   #1
Unhappy
refinishing hardwood floors that have particle board over them
I bought a house that has hardwood floors throughout but the previous owner used ring nails and put particle board over the top of it as a subfloor and laid carpet. What is the best way to take up the particle board with as little damage to the hardwood floor as possible? I am doing all the work myself (family members know how to do it but won't help) and I really don't know what I'm doing.
skullface is offline   Reply With Quote
Old 05-31-2009, 10:43 PM   #2
the ring shanks are gonna be a bear. get some pry bars and tear up the plywood. you could set a skilsaw and cut some sections for easier removal instead of trying to get the whole 4x8 sheet up at once. Just make sure the skilsaw blade is set a bit shallower than the thickness of the plywood- you dont want to accidently cut into the hardwood.
By splitting the plywood out this will still leave the ringshank nails, but at least the head will be up a bit (the thickness of the plywood)
now use your prybar and a scrap of wood to pull the nails.
Once that is all done it is time to sand the floors.. You have a lot of work to do. hopefully it isnt to big of an area. And SHAME on your family members not to offer a hand
What have I done is offline   Reply With Quote
Old 06-01-2009, 10:47 PM   #3
Hey, I like your idea. I'll have to try it. I know, unfortunately you can't choose your family right.
Old 06-02-2009, 06:52 AM   #4
Although it's going to be more time consuming, I would recomend trying to locate & remove the nails with the particle board in place rather than sawing it into smaller sections. #1, you run the risk of sawing too deep & damaging the flooring underneath the particle board. #2, directly on the hardwood could damage the floor. I would buy a pry bar that digs into the particle board & gets under the nail head. We called them a cats claw, or sheeps foot. I don't know the real name, but they do work well. Good luck with the project.
pinwheel45 is offline   Reply With Quote
More On This Topic
In this clip, I'd like to talk about the cove. The cove is this area behind me. It's a curved surface that curves away from the shooting side of the studio up into the wall so that there's no seam. These can be made out of - well, I've made simple ones... Read More »
Remodeling a Difficult Room
Remodeling a Difficult Room by Expert Village
This is our activity room, and we have classes and I have an art table set up over here, and a desk for creative writing, and then this ladder goes up to the office. This room has changed more than any room in the house. This used to be an art... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we would cutting out partition sides. Our partition side pieces would becoming out of our remainder of our 4x8 sheet of plywood. First I'm going to measure and mark it at 28 inches. Next I'm... Read More »
Hi! I’m Tad Donley and I’m speaking in behalf of Expert Village. I’m giving you tips on how to make your own recording studio. Hardwood floors, let me tell you about that, I would be wary of hardwood floors, it is the mirror effect that... Read More »
Hard Wood Floor Care
Hard Wood Floor Care by Expert Village
Caring for hard wood floors is something people debate on a lot. First of all, you want to sweep a lot. You want to use a broom that has bristles that are frayed at the end so that way you don’t have to mess with scratching the ground, scratching... Read More »
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
Refinishing Hardwood floors ponch37300 Flooring 2 11-02-2008 05:08 PM
Refinishing Hardwood Floors Kyle Flooring 4 11-17-2007 12:08 PM
Installing backerboard - replace particle board? salvop Flooring 9 08-13-2007 08:11 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
