-   -   Refinishing Hardwood floors (http://www.diychatroom.com/f5/refinishing-hardwood-floors-31078/)
ponch37300 11-02-2008 01:25 PM
I am wanting to refinish my hardwood floors in some of the rooms. I have done a lot of research on this but still have some questions. One is that in some of the rooms there are a few gaps in the pieces of hardwood, how big of a gap is acceptable if any? If these gaps are not acceptable what is the best method for fixing this problem? Also there is some leveling cement around some of the edges under the carpet, i think i can just sand this down unless someone knows different? I'm sure i'll have some more questions but just trying to figure out if refinishing is even possible right now, hopefully it is! Thanks
Allison1888 11-02-2008 02:31 PM
refinishing wood floors
Depending on the size of the gap, you typically fill in the space by patching in new wood. That can be tricky in terms of how it blends, but if you're adding a colored stain to the floor it should work fine. Otherwise you just find wood that matches as best you can. Here's an article that can help, too.
http://www.selfhelpandmore.com/building/flooring/refinishing-hardwood-floors.php
ponch37300 11-02-2008 04:08 PM
Thanks for the repley. guess i will be replacing some wood cause there are some gaps bigger than 1/8 inch or so. It will be a colored stain so hopefully it will blend decent. Thanks for the link
