Refinishing Hardwood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 04-04-2009, 08:07 PM   #1
I just finished using a oil based minwax stain on my floor. How long do i need to let it cure and do i need to do anything before i apply the water based poly finish.
onenonlydano is offline   Reply With Quote
Old 04-05-2009, 08:07 AM   #2
Follow directions, usually 24-48 hrs is good. Vacuum and wipe with a tack rag to get up dust and stuff.
Old 04-05-2009, 07:34 PM   #3
Master Craftsman
Big Dave's Avatar
As long as you applied the stain and wiped off the excess you can coat the next day. I use Bona Kemi Bonaseal as a bonding agent between the oil based stain and my first coat of final finish. For a final finish I use Bona Kemi Mega. You want at least two coats of Mega and as long as you apply within 48 hours there is no need to sand. I will apply the first two coats of Mega then wait for at least a week then lightly sand it with a Maroon scotchbrite pad, vacuum, tack with a water dampened rag and apply the last coat of Mega.
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 05-21-2009, 02:54 PM   #4
Help!
So what should I do if I applied the stain and didn't wipe very much of it off because I liked the color? We did this on Sunday and 4 days later, it's still sticky. Any suggestions?
new owner 730 is offline   Reply With Quote
Old 05-23-2009, 09:46 AM   #5
Oil & water don't mix. It could actually take days for the oil base stain to dry well enough to apply waterborne finish & get it to adhear. Why not use an oil based poly?
pinwheel45 is offline   Reply With Quote
Old 05-23-2009, 10:38 AM   #6
I second the last post. I don't know why you are applying a water base over an oil base. You may have problems with the water base adhering. Don't the directions on the can say not to do this?
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 05-23-2009, 11:03 AM   #7
I make my living installing & refinishing sand on site wood floors. I've refinished some floors using waterborne, but it's been years. Now, I'm purley an oil based finish man.
Old 05-23-2009, 02:02 PM   #8
It's hard to beat an oil based finish on a floor. Most people don't like the fumes or the time it takes to dry but it is worth it. The water based finishes are getting better though.
Can I install hardwood flooring over an existing hardwood floor? Max1119 Flooring 12 05-31-2012 12:17 PM
Spot repair of water based poly hardwood floor flyfisherman Flooring 5 05-06-2009 09:00 AM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 07:11 PM
