Old 09-04-2008, 04:58 PM   #1
Refinishing Hardwood
I'm about to refinish some hardwood floors, and I don't have a drum sander. Is it possible to sand the entire floor with a belt sander?
Mr Shankly is offline   Reply With Quote
Old 09-04-2008, 05:49 PM   #2
Flooring Specialist
Assuming we're talking about a professional grade belt sander and not a hand held belt sander, both will perform the same function. The belt sander is the preferred piece of equipment used by most contractors. Drum sanders tend to leave more chatter than a belt sander.
Wordimus is offline   Reply With Quote
Old 09-05-2008, 07:08 PM   #3
curious my self, can you use a so called, regular belt sander to do your hardwood floors? This question is not to be confused with my mindset, I really want to know if its possible, I've seen replys on this before, I guess my real question is why can't this be done, I appreicate anyone's thoughts on this, thanks
DUDE! is offline   Reply With Quote
Old 09-09-2008, 12:29 PM   #4
Best to rent a flat panel sander from HD. THese are far more forgiving than the traditional belt "lawn mover type" of sanders. Get a ton of paper, you will need it. What finish are you putting down?
glover10604 is offline   Reply With Quote
Old 09-09-2008, 05:56 PM   #5
I'm not presently doing my floors, the op is, I was just curious as to if you could use your belt sander and do the floors, don't know if its because it would take you forever or if you couldn't do a good job with it, never got a good answer on it. I've used the rentals before, heavy to load in the car or truck, ton of dust everywhere. thanks for replying.
Help w/ refinishing hardwood stairs...!!! bujaly Carpentry 22 03-16-2009 03:05 PM
Refinishing Hardwood Floors Kyle Flooring 4 11-17-2007 12:08 PM
Cost of Refinishing Hardwood Flooring ? Piney Flooring 2 03-27-2007 04:33 PM
Refinishing Hardwood bgillette79 Flooring 8 09-08-2006 03:14 PM
Price for refinishing hardwood floor darren Flooring 3 01-03-2006 06:44 PM
