Refacing Stair Treads - Flooring - DIY Chatroom Home Improvement Forum
Old 08-05-2010, 08:04 PM   #1
Refacing stair treads
I had decided to re-face my existing stairs with engineered oak treads. I completed the set of stairs leading to the lower level without problem by cutting the nosing off the existing "ruff" treads and installing new risers and the oak treads over the existing ones. The bottom stair set is completely enclosed.
Then the problem was realized.
My home is a spit entry and the set of stairs leading to the main level has 6 treads with the first 3 exposed on the right side. If I use the same method as the bottom set you will be able to see the old tread and riser from the side view.
What should I do?
Stair newbee is offline   Reply With Quote
Old 08-05-2010, 08:42 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 196
To use the engineered treads over existing treads, cut the return noising off the existing tread, (most times the return nosing is nailed and glued on and can be removed easily) take the Scotia mold off the front and side under the treads.
Install the stair brackets to hide the part you cut off and replace the Scotia mold front and over the brackets.
Here is a link to show you some brackets.
http://www.google.com/images?rlz=1C1...iw=800&bih=479
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
gma2rjc (08-05-2010)
Old 08-10-2010, 11:35 PM   #3
Stair Hangers
Interesting option. I'll do some research locally to see what's available.
Thanks!
New stair treads and flooring rickkeeter Flooring 2 02-24-2010 11:16 PM
Ugly old painted stair treads, with seriously raised grain. Salvageable? CharmCityFixer Flooring 9 01-29-2010 07:40 PM
sanding pine stair treads. Need adivce. Mike in Arkansas Flooring 2 07-20-2009 11:01 AM
Scribe Cutting Oak Stair Treads kcdave Carpentry 2 03-18-2008 08:13 PM
Cracked Stair Treads pickel011 General DIY Discussions 1 12-27-2006 04:31 PM
