Reducing Slope On 2nd Story Balcony Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 08-27-2011, 03:28 PM   #1
reducing slope on 2nd story balcony floor
I'm building a new home with a 34 x 14 ft. 2nd story covered balcony. Broward County Florida building code requires a 4" slope to the floor for drainage even though the area is covered by a roof. This slope is very apparent and i'm looking for a way to reduce it using a sub-floor system. Using tile and building one end up with mud won't pass inspection and adds too much weight. I don't want a wood floor look so that rules out Trex, etc. Is there some type of system that can be installed to allow drainage and permit a snap together tile system?
lisaburgess is offline   Reply With Quote
Old 08-27-2011, 08:51 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 422
You need a minimum slope of 1/4" per ft., 3/8" would be better, so 4" in 14 ft. is right. The balcony may have a roof, but it's not enclosed, therefore it will get wet.
Jaz
Old 08-28-2011, 12:18 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I wonder if it is possible for an alternate to be approved via a code variance.
Take a look at Schluter's TROBA-PLUS drainage system for decks and see if it would fit the bill.
http://www.schluter.com/7_2_troba_plus.aspx
Doesn't make since to me that the local government could force a 4" slope on that type of improvement. Hell...all of your marbles would roll away.
XXX
Shower floor slope Not Sure Building & Construction 11 06-10-2008 11:12 AM
Noticeable slope on main floor... andersp Building & Construction 13 01-17-2007 07:59 AM
Slight slope to floor sweetsue777 General DIY Discussions 3 01-10-2007 12:58 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 09:23 PM
Reducing size of very large air-vent returns in floor? AllGoNoShow HVAC 3 09-19-2006 09:36 PM
