Reducer Question - Flooring - DIY Chatroom Home Improvement Forum
Old 05-15-2012, 07:45 PM   #1
Rewards Points: 209
Reducer question
I've just installed laminate locking flooring (Chesapeake brand, blond maple) and have reached the final transition to put in. I have to put a reducer in and need some advice.
Currently there's a gap of 1/2 inch (height) between the lower level and upper level planks and that's what the reducer is sized for. However, the reducer instructions call for a 1 inch space (width) to accomodate the u-track that it snaps into and IF I do that it will create a full 1 inch gap (height) between lower and upper planks.
As u can see from the pic the lower level goes right up to the upper level so if I install the u-track I'll have to drill, and subsequently, screw into the floating laminate.
My questions are....
1. Can I screw into the laminate? Will that cause bowing or some other issues with the rest of the floor?
2. If I rip a wider clearance for the u-track (causing my height to reduce to go from 1/2 to 1 inch) do they make reducer's that accomodate 1 inch?
Any input would be greatly appreciated.
Here's the instructions for the reducer (lumber liquidators, btw) http://www.installationadvice.com/pdfs/reducer.pdf
Last edited by Zamboknee; 05-15-2012 at 07:51 PM. Reason: Wanted to add instructions
Zamboknee is offline   Reply With Quote
Old 05-15-2012, 07:56 PM   #2
Rewards Points: 13,450
I'm not there to see the whole job and only have a picture to go by, but from what I can see that lower floor area should have been built up with plywood before the flooring went in, or the other floor needed to have whatever your trying to cover up removed so they came out even.
In order to install that strip you have your going to have to remove that last row of flooring and rip the pieces so there not so close to the step in the floor.
If you nail or screw anything through that flooring it will buckle or the seams will open up.
Old 05-16-2012, 01:39 AM   #3
It seems that you could find a better transition for this. I would likely use a carpet reducer molding. As it will overlap the higher flooring and can cover the gap. Or if is fairly easy to make one out of solid wood, this would be the best route.
RhodesHardwood is offline   Reply With Quote
Old 05-16-2012, 08:42 AM   #4
Rewards Points: 209
Can I just rip some particle board to put under the u-track to accommodate the new height?
Old 05-16-2012, 09:27 AM   #5
Too Short? Cut it Again!
Particle board will disintegrate if it moves at all. As suggested a hardwood surface transition seems your best bet. Make it wide enough to reduce tripping hazzard.
Old 05-16-2012, 09:42 AM   #6
If a carpet reducer is wide enough it will sit right on the higher flooring. So it probably would not be necessary to build it up.
Old 05-16-2012, 08:39 PM   #7
Rewards Points: 209
what about ripping scrap laminate and using THAT to screw down (and provide enough height) the u-track?
Hydronic boiler pressure question. RickInMissouri HVAC 1 01-23-2010 04:57 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
