Old 03-17-2009, 06:04 PM   #1
Default Redoing an old subfloor
I'm looking to lay down new flooring (3/4" hardwood, 4 1/4" wide planks) in my house (built in 1945), and I know that the subfloor needs to be redone first as there are certain rooms with multiple dips of up to 2 inches, and all sorts of 'wavyness'. The current flooring is parquet, and this is visible to the naked eye.
Anyhow, I started tearing up the flooring in one room to see how bad the situation is. The parquet isn't coming off cleanly, so I've been lifting up the (damaged) 3/8" plywood beneath it. Beneath that, it looks like I'm down to the original subfloor, which is 3/4" x 7" planks laid at an angle (20 degrees off perpendicular, maybe?) to the joists. This planking is relatively weak as you feel (and see) it flexing when you walk across it. The joists are 2" x 10", and look to be in good shape, although they're surely off level. They are spaced at 20".
So, what would be the recommended sub-flooring to put in? I was originally planning on ripping up the planks, shimming the joists (maybe sistering the worst offenders), and laying down 3/4" T+G plywood. However, isn't such a floor normally laid on joists that are spaced at 16"? Should my subfloor be thicker because of the wider joist spacing?
Also, one of the walls in this room is a load bearing wall (running perpendicular to the joists). Since the wall was built on top of the old subfloor, I know I'll need to reinforce underneath it as I take up the old subfloor (I want to minimize movement of the wall, and subsequent plaster fixups). I was planning on going joist by joist, and putting in little lengths of 2" x 10" between the joists, under the wall. Is this sufficient? What is the best way to attach these?
Any response would be greatly appreciated!
Chris
chhamilton is offline   Reply With Quote
Old 03-17-2009, 10:03 PM   #2
motivator
Speedball's Avatar
Sorry I don't have an answer but I have a similar situation with 3/4" 1'x6" and will be deciding in the next few weeks what to use for the next layer. For my place it may be 3/4" 4'x8' sheets of Plytanium BC underlayment (plywood).
Not sure if this is proper but the only thing I know to do at this point.
Good Luck.
............Enjoy...Pat
Speedball is offline   Reply With Quote
Old 03-18-2009, 10:35 AM   #3
Originally Posted by chhamilton View Post
...with multiple dips of up to 2 inches, and all sorts of 'wavyness'.
That should read 1/2" and not 2" dips. *brainfart*
No comments on how to proceed? I'm mostly concerned about ensuring that the load-bearing wall is properly supported and dealt with.
Also, for all you tile guys: Eventually, I'll be redoing the subfloor of the whole main floor, including the kitchen. In the kitchen, I'd like to put down tile (it's currently a god-awful lino). What would be the minimum recommended subfloor here? Ideally, I'd like the finished height of the hardwood and the tile to be as close to flush as possible. What to people think of using DITRA directly on plywood instead of cement board?
Old 03-18-2009, 10:50 AM   #4
ccarlisle's Avatar
Well, from a tilers point of view, a wooden floor system (joists+subfloor) must meet local building codes first and then be placed on joist a maximum of 16"oc to meet most standards I am aware of.
Should also meet the deflection criteria for floor movement and I doubt your system does that with 20"oc joists. Will have to be beefed up considerably with braces.
That is, for a good job where the tiles don't crack on you in a month...anyone could give you less, not many could give you that or more.
Sorry posted a bit quick there. With Ditra, you could get away with 20"oc joists but you'd need a special 3/4" subfloor (maybe even a 3/8" underlayment). See Schluter for exact requirements.
ccarlisle is online now   Reply With Quote
Old 03-19-2009, 08:56 PM   #5
Still no comments on how to treat the subfloor? (Regarding the load-bearing wall, etc)
Old 03-20-2009, 05:01 PM   #6
I finished tearing up the parquet and 5/8" plywood, and am down to the planking. Now that I can see the whole area, it turns out the joists are not 20" OC... most are spaced 18", some 16", some 20" and even a few at 24". The planks have had a hard life (I think they've had several subfloors put down and torn up over the years), with a lot of them split and almost all of them crowned or warped in some way. How thick should the structural subfloor be to handle up to 24" joist spacing? What should I put on top of that before laying down the hardwood?
More On This Topic
And here we are inside the permanent shanty. You can see that it's roughly of an 8 by 6 foot construction. Make out of luan and 2 x 2's cut from 2 x 4's. It has all the amenities of home but in a much, much cruder fashion. Isn't that right great pumpkin... Read More »
If you are at a loss as to what to do with your keepsakes, handed down furniture, year books, children’s toys or holiday ornaments, you should look up and consider your attic. Homes used to be made with stairs that went to the attic. Here children... Read More »
Remodeling, whether it is in the garage or in the house is a huge undertaking. One of the easiest projects is building a non-bearing interior wall. The tools are basic, as are the needed carpentry skills. The condition of the floor and ceiling will... Read More »
In bi-level houses, transporting soiled laundry downstairs wastes considerable effort. A simple solution is to transform a closet into a laundry chute. There's no need to give up an entire closet; a small addition against one wall can be an effective... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I'll be talking about the types of materials that we're going to use for our project. The material that we are going to be using first is 3/4" oak plywood, this plywood comes in 4 feet wide by... Read More »
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 08:29 AM
Subfloor Help, Please! OmahaGirl Flooring 1 01-26-2009 10:06 AM
Replaced section of subfloor but it's 1/16" higher. Is that a prob? Piedmont Carpentry 1 08-29-2008 12:12 PM
New pre-finished hardwood over an old subfloor dmush Flooring 0 08-05-2008 08:16 PM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 09:39 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
