Redoing Kitchen - Flooring - DIY Chatroom Home Improvement Forum
Old 05-10-2010, 11:01 AM   #1
Redoing Kitchen
I am going to be ripping out all of the old cabinets. I will also be putting in a dishwasher and new flooring (probably hardwood). The cabinets I am using will probably be the stock ones you can purchase at lowes or home depot. My question is, should I put the cabinets and dishwasher in, and then put flooring on? Or cover entire floor with new hardwood, and then add the cabinets and dishwasher?
Also, when tiling a bathroom, do you put the tile down first and then sit the toilet on top, or toilet first and tile around?
ws450r is offline   Reply With Quote
Old 05-10-2010, 12:31 PM   #2
Ivy
I myself had the same question when renovating my kitchen. I ended up laying the tile first and then installing the cabinets and appliances over the flooring. Turned out great! It's been 2 1/2 months since I started and am still not finished as you can see. Tile the bathroom floor first and then install the toilet... Patient is key.
Redoing Kitchen-100_0195.jpg   Redoing Kitchen-100_0196.jpg   Redoing Kitchen-100_0358.jpg
Ivy is offline   Reply With Quote
Old 05-10-2010, 03:58 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Cabinets over tile is one thing, cabinets over hardwood is an entirely different deal. What happens when the wood floor gets wet and buckles then takes the cabinets with it? Insurance may not pay for all of the damage.
I would install the cabinets then install the hardwood up to the cabinets, that's usually the way it is done.
As far as the toilet?
Never tile around a toilet.
Always set the toilet on top of the tile.
Same goes for toilets and other floorcoverings as well.
XXX
Old 05-10-2010, 04:15 PM   #4
If I go with hardwood up to the cabinets, will I have any trouble getting the dishwasher to slide in? I know there is not that much difference, but it seems like everything fits so tight these days when messing with this stuff.
Old 05-10-2010, 04:18 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
It's done every day. Dishwashers have a little adjustment in the front legs if you need it. Hardwood that is 3/4" thick shouldn't be a problem.
XXX
Old 05-10-2010, 06:27 PM   #6
sorry but cabinets should be sitting on floor or shimmed to that height. i didnt do it that way and dish washer install sucks. and i used 1/2" engineered hardwood flooring. never again
The older I get the better I was
Old 05-10-2010, 07:18 PM   #7
DIY staff
Rewards Points: 7,174
The cabinets must sit on top of the flooring--If you wish to add your hard wood after the cabinets--
lay 3/4 inch ply under the cabinets so the cabinets are the same height.
It's so much easier to install the flooring first that the cost of the extra wood is long forgotten ---
Speaking of elevations----don't forget to lower the drains for the sink--new -under mount sinks with a disposer need a lower drain.---Mike---
kitchen design: should we remove inner wall(s)? ilyaz Kitchen & Bath Remodeling 4 10-26-2010 07:59 AM
Redoing kitchen cabinets CheshireFool Carpentry 10 03-25-2010 04:18 PM
Ideas Regarding Kitchen Remodeling Kristal Kitchen & Bath Remodeling 2 12-20-2009 09:44 AM
Just bought a 1946 house, redoing kitchen, what electrical fixes/upgrades needed? TomServo Electrical 18 09-21-2009 06:48 AM
