Old 06-11-2007, 03:34 PM   #1
Redoing hard wood floors
Hi,
I will be redoing some old hardwood floors that have been covered with carpet for about 30 years. The carpet and staples, etc are up and out, but there is a thin layer of paint or sealer someone put down. I need to sand and stain - so here are my questions:
- What kind of sander should I use? I have heard scary stories about drum sanders but I know they are fast. I have never used one before, should I give it a try or use something a little less dangerous?
- Stain – water or oil based? I hear water dries too fast but oil base can look kind of yellow.
Thanks!!
Sarah
sarahmbuc is offline   Reply With Quote
Old 06-12-2007, 09:06 PM   #2
Master Craftsman
Big Dave's Avatar
For a DIYer I would recommend a 12"x18" orbital that can be had at rental stores. You will need to start with a course sandpaper and work up through the grits to at least a 100 grit. It will be much slower than a belt sander but you can't screw it up. Go slow with it too and let it do the work. You will need to use a ROS sander for along the edges. Stay away from Water based stains. Oil based stains will not yellow but oil based finishes will. You can use a Oil based stain and water based finish but be sure to let the stain dry for 24 hours before coating with a water based finish.
Do one thing at a time, do it well, then move on.
Big Dave is offline   Reply With Quote
Need some advice on how to remove ceramic tiles over wood floors. sandman512 Flooring 4 09-02-2007 12:03 PM
Ceramic over Old Hard Wood Floor???? cuinthemoon Flooring 1 08-13-2007 09:23 PM
Washing my wood floors J187 Flooring 1 11-14-2006 11:13 PM
Removing Linoleum backing paper from wood floors SatDoug Flooring 4 09-17-2006 12:00 AM
Floating Wood Floors? dag Flooring 1 06-22-2006 10:40 PM
