Redo Stairs - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-04-2013, 07:28 PM   #16
Stairguy
Millertyme's Avatar
Rewards Points: 508
16 gauge is a little more common but both could be used, and use plenty of constructing adhesive before applying the treads
Millertyme is offline   Reply With Quote
Old 10-17-2013, 06:41 AM   #17
Rewards Points: 1,046
What should be the minimum depth for a tread (I live in Michigan if it makes any difference)?
If I go with Retrotreads from Stairtek, I will have between 9"1/2 and 9"3/4 (bullnose included).....Is that OK?
I've read somewhere it should be 10" + 1" for the nose, so a total of 11"
1 more question: 18 gauge nails are not strong enough for treads, right?
french_guy is offline   Reply With Quote
Old 10-20-2013, 09:55 AM   #18
Stairguy
Millertyme's Avatar
Rewards Points: 508
Around here 9" is acceptable although national building code is set at 10". Measured from face of riser to face of riser" overhang may not exceed 1-1/4
I would not use a gauge less than 16g on treads
The Following User Says Thank You to Millertyme For This Useful Post:
BigJim (10-20-2013)
Current house - stairs JulieB Project Showcase 20 04-09-2013 02:38 PM
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
How to finish basement stairs mark2741 Flooring 9 11-13-2012 01:09 AM
Exterior Stairs to Coach House Need to be Repaired/Replaced. Help Appreciated! 2031pratt Carpentry 9 04-07-2010 03:43 PM
Help with staining my stairs kimber Flooring 2 12-04-2009 08:45 PM
