Redid Laminate Floor And Made It Worse - Flooring - DIY Chatroom Home Improvement Forum
Old 03-05-2012, 06:28 PM   #1
redid laminate floor and made it worse
My laminate has creases where the bevels are.I redid a few rows of planks and broke the tongue off of some of them accidently.I now have spaces in between planks.How can i fix it?Help!!
Dee M is offline   Reply With Quote
Old 03-05-2012, 07:11 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Quit breaking the tongues!
What creases? What bevels?
Are you breaking the tongues on purpose? Why?
What kind of laminate?
titanoman is offline   Reply With Quote
Old 03-05-2012, 07:18 PM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
Post up a photo.
We're you using the block to "tap" them in is that how they broke?
There no good now once they brake like that
JetSwet is offline   Reply With Quote
Old 03-05-2012, 09:29 PM   #4
Tarkett laminate floor
The tongues broke when pulling them apart.They seem to break easily.I would never do that on purpose.My guess is that we will have to dismantle the floor up to the problem area and replace them with new planks.
Old 03-05-2012, 10:23 PM   #5
Disabled wood vet
titanoman's Avatar
I believe so.
If you post a picture or two, one of our very capable flooring experts can help you with your questions.
Old 03-05-2012, 10:37 PM   #6
Rewards Points: 13,748
Several things can cause it to buckle.
Installed to tight to the walls or door jamb area,
No vaper barrier in the crawl space.
Someone installed it running through a doorway and did not install a trasition strip.
Someone nailed into the flooring when installing the 1/4 round.
