Old 03-25-2010, 02:28 AM   #1
live & learn
Redgard and radiant heat flooring
Does anyone know if Redgard has a compatibility issue with heated flooring? I can't find any limitation notes on the web sites but I thought I'd through the question out to some pros. I'm coating Hardi backer prior to putting on the heating mats and tile.
xplorall is offline   Reply With Quote
Old 03-25-2010, 06:58 AM   #2
Doer of Many Things
poppameth's Avatar
I don't use RedGard but I know most systems I've seen, especially Schluter Ditra, always recommend you apply the membrane over the heat, not under it. You use self leveling compound or thinset to embed the mat and then apply the membrane to the finished surface prior to tiling.
poppameth is offline   Reply With Quote
Old 03-25-2010, 06:34 PM   #3
Electric Radiant Heating
warmsmeallup's Avatar
Sluter and Redgard both add some insulation value. Though it may be minor, make very sure you have less resistance above the element before installing it.
warmsmeallup is offline   Reply With Quote
