#1 |
Rectified Porcelain, DITRA, and unlevel surface tips
I'm installing a 12x24 rectified porcelain floor tile with a 1/8 grout line on a slab-on-grade with DITRA applied. It'll be set in a 1/3 offset pattern -- so the first tile will be 8", the 2nd one 16", the 3rd the full 24".
My main questions -- with a tile this flat and without variation, what are the best ways to avoid or hide lippage? The floor is not QUITE level; it has about a 1/8" over 2' wave in it; in other words, every 4 feet there is a dip about 1/8" in the middle. I COULD get self-leveling concrete poured in here, but it seems like a bit of a waste when the variation is that slight. I've got the high points marked on the walls and was planning to use a 1/2" square notch to give myself a little extra wiggle room. Any pros want to weigh in here? Since I'm laying the DITRA over it first with a 1/8" v-notch, is that going to amplify or help hide the high spots? Besides self-leveling... Is there any prep work I can do to help myself keep things straight, level, and otherwise happy? This is the first full floor I'm doing, but I've installed tile using thinset before. (Bathrooms & Backsplashes...) Just haven't done a large area with a lot of precision... I'm only doing 100 sq ft here, but I'd like to make it look really good. |
#2 |
(Oops, I should've put this in the Tile/Ceramics/Marble subform. Sorry. Admins, plz to move?)
#3 | ||||
Tileguy
The industry standard for flatness is: "within 1/4" in 10 ft. AND 1/16" in 12" of the required plane". Your floor may be close to this standard, I'd have to know more. Plus, with large tiles I recommend that the floor be within 1/8" in 10 ft. instead of 1/4".
Patching the floor should be done before you install Ditra. Quote:
Installing anything can not improve the situation. The humps will get a little bigger is all. Quote:
Jaz
Tile 4 You LLC Troy, MI KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME! |
| Display Modes | |
