Old 10-11-2008, 11:23 PM   #1
recommended subflooring for hardwood on concrete slab
We have built an addition to our home and a looking for information about installing hardwood flooring on a concrete slab. The slab meets minimum code requirements and the room is a three season room. (We live in the midwest.)
What kind of subflooring should be installed under 3/4" red oak?
blackcat is offline   Reply With Quote
Old 10-13-2008, 12:04 PM   #2
Floorwizard's Avatar
Someone will chime in on the answer for 3/4 oak.
But why not float an engineered product?
Floorwizard is offline   Reply With Quote
Old 10-23-2008, 01:17 AM   #3
I floated an engineered hardwood over concrete slab using Floormuffler underlayment, which acts as both a sound deadener and a moisture
barrier. Came out great.
Gevans17 is offline   Reply With Quote
Old 10-23-2008, 09:11 AM   #4
Moderator
Termite's Avatar
You'll have to get plywood under it...No alternative. You can't lay plywood right on your concrete slab, so it'll have to be furred up on sleepers.
Bad idea if you ask me...Just asking for moisture issues with the floor and the substrate. I'd look at a floating engineered floor if it were me.
Old 10-25-2008, 06:58 AM   #5
I have been looking at Junckers hardwood flooring - floating installation and can be done over a concrete slab.
http://www.junckershardwood.com/
Also looking at putting Floor Muffler under it for the underlayment.
http://www.floormuffler.com/floormuffler.html
Old 10-26-2008, 06:15 PM   #6
I used a product called DriCor which allows any water that penetrates the basement to run to the floor drain. Adds about $1-80 per square foot to your costs. Its easy to lay, but slightly time-consuming. I can recommend it. You can also build internal walls directly over the top of it. It also allowed me to run network and speaker cables underneath it.
Paulustrious is offline   Reply With Quote
pouring a level concrete slab over sloped concrete Jayne Building & Construction 4 05-11-2008 09:55 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 06:14 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
