Old 06-29-2009, 05:47 PM   #1
Default Reccommended Flooring For Garages?
Paints or I saw "liquid granite hybrid polymer floor"....
http://www.garageenvyshop.com/premiumflooring-2.aspx
Can anyone recommend paints or other stuff (epoxy?) they have used successfully or any horror stories to stay away from?
I'm closing on a house in a few weeks and I want to do the garage floor. My budget would be about $150.
Its a 2 car detached garage. Let me know if my budget sounds unreasonable.
limitdiy is offline   Reply With Quote
Old 06-29-2009, 08:47 PM   #2
New home owner!
Red Squirrel's Avatar
I'm curious to know the options as well. I recently bought a house and my garage floor is very rough, and there is also a crawlspace under it so I want to ensure I preserve the strength of it so it never caves in. What I'm thinking of is a thin very flat layer of cement just to flatten it off and have a slight incline so any liquids go out the garage door.
But I'm curious to see what other options there are as well.
Old 06-29-2009, 10:16 PM   #3
From what I'm reading, its paint vs epoxy.
Is epoxy alot harder to put on than paint?
Old 06-30-2009, 09:15 AM   #4
gravity always wins
Epoxies will be more durable, however, they don't breath. First thing is to check if there are any moisture issues. Tape a 2'x2' piece of 6 mil poly down to the floor. Duct tape the edges. wait about 3 days and see if there is any moisture condensed on the under side of the poly or if there is any dampness present on the concrete. If it's dry, then you'll probably be Ok for epoxy. If not then forget it. The epoxy will trap moisture. The vapor pressure will blow the epoxy off of the surface. If there is moisture, then go with a latex based traffic deck coating. Epoxy is not really harder to put down than paint, but you need to follow the manufacturers instructions. Be sure to use the proper roller covers. Some epoxies will desolve the glue on cheap covers and leave you with fuzz in your coating. Also check the manufacturers recommendation on second coating. Cleaning and prep are very important. Nothing will stick to oil spots or grease. Previous sealers or paints will need to be dealt with.
Old 06-30-2009, 10:23 AM   #5
What is 6 mil poly?
A latex based traffic deck coating is good for a normal smooth concrete slab in the garage?
Thanks for the info.
If I do go with paint, can you still use the vinyl chips?
Old 06-30-2009, 04:43 PM   #6
sestivers's Avatar
Actually it's thousandths of an inch (0.006").
Steve
sestivers is offline   Reply With Quote
Old 07-01-2009, 09:20 AM   #7
gravity always wins
There are "next generation" latex coatings that work well on garage floors. They are not as tough as epoxies to be sure. If you plan on some kind of design with vinyl chips,then they need to be part of a coating system. You can't just toss them into any paint you choose. 6 mil poly is polyethylene sheeting that you buy in a roll, usually clear, sometimes black. Use clear to test for moisture.
Old 07-01-2009, 06:00 PM   #8
Tileguy
limitdiy: "What is 6 mil poly?"
TrueHardwoods: "6 mil poly is just a 6 millionsth of an inch polypropolene (plastic) sheet."
Almost every day I leave here with a smile on my face. I love it!
Old 07-02-2009, 08:21 AM   #9
gravity always wins
Guess that's why we keep coming back
Old 07-02-2009, 09:47 AM   #10
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Have some respect for the "Flooring Expert".....please.
- Build Well -
Old 07-02-2009, 04:37 PM   #11
STB
I'd use the epoxy. I used the paint bought from Lowes for my floor about two months ago and his a couple of small spots that have chipped already from pulling my motorcycle in and out. It may cost a bit more in cleaners and degreasers to get the floor clean prior to installing the epoxy, but in the long run its worth it.
STB is offline   Reply With Quote
More On This Topic
Resin can provide a thick, durable, clear surface for a tabletop. It doesn't take any special skills to apply, but it does take patience. Be sure to do the prep work, and the actually application process can be done in no time. You can embed newspaper... Read More »
Hi I'm JD and I am here to talk to you about maintaining your instruments and cleaning them. Why should we clean our instruments? Well I guess its since their air phones, that meaning air travels through them, we don't want to impede the air or give it a... Read More »
You may have seen shop windows that are painted for the holidays and special occasions and wondered how you could achieve the same look at home, but with easy clean-up. It is really easy and fun! You may wonder why the "Things You'll Need" list calls for... Read More »
Resin is not only for those cool patio chairs or tables, or for those adorable garden gnomes and sculptures. Resin can also be a very useful tool when repairing a home--especially useful in restoration. Read More »
Though the water cycle is a relatively simple concept to grasp in the abstract, it's much easier for students to understand the entire process when they can visualize it. You can create an interactive lesson about all the components of the water cycle... Read More »
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 11:00 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 10:00 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 09:06 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 01:32 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
