Real Wood Floor Underlay - Flooring - DIY Chatroom Home Improvement Forum
Old 09-05-2007, 12:23 PM   #1
cj2
real wood floor underlay
I am putting real wood flooring down in my sitting room where i currently have carpet with quite a thick underlay, providing it is level would it be ok to lay the wood flooring on the underlay i already have. the floor underneath is concrete,thanks guys
cj2 is offline   Reply With Quote
Old 09-05-2007, 08:42 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 422
What do you mean by underlay? Underlayment is usually the second layer of plywood in a floor system. Underlay, might also mean the carpet padding, you don't mean that...do you?
Engineered hardwood flooring can go over concrete that is flat and dry. What type of wood were you considering?
Jaz
Old 09-05-2007, 09:06 PM   #3
Floorwizard's Avatar
if it is a floating hardwood, then you will need a pad with a moisture barrier before you float the floor over the concrete.
A solid wood floor would be more difficult.
Floorwizard is offline   Reply With Quote
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
Permanent Wood Foundation Question opee Building & Construction 2 03-19-2007 09:27 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 04:16 PM
