Re-tiling Around Fireplace - Flooring - DIY Chatroom Home Improvement Forum
Old 01-02-2012, 08:28 AM   #1
Re-tiling around fireplace
I am re-tiling around fireplace floor and inside mantle before I put down laminate flooring. I had no problem removing tile on floor, but when I started to remove the tile surrounding fireplace inside the mantle I see it was grouted directly to drywall and pulling drywall off with it. Before I go any further...am I going to have to put new drywall underneath it all if I do this? I've tiled floors before but not on wall. Thanks!
lusylou is offline   Reply With Quote
Old 01-02-2012, 08:43 AM   #2
Rewards Points: 14,010
If it was mine I would just remove the drywall and replace it with tile board.
lusylou (01-02-2012)
Old 01-02-2012, 09:02 AM   #3
DIY staff
Rewards Points: 7,174
Post a picture if you can---
Old 01-02-2012, 09:28 AM   #4
A Little Of Everything
Rewards Points: 1,364
That's what I'd do too.
DrHicks is offline   Reply With Quote
The Following User Says Thank You to DrHicks For This Useful Post:
Old 01-02-2012, 10:15 AM   #5
Fireplace pic
hopefully you can see pic attached I'm new at this!
Old 01-02-2012, 10:27 AM   #6
I can fix that!
Rewards Points: 35
Yep, remove the drywall and put up tile backer board.
kuhlman is offline   Reply With Quote
The Following User Says Thank You to kuhlman For This Useful Post:
Tiling masonry fireplace thewoodguy Tiling, ceramics, marble 11 12-14-2011 10:09 AM
Tiling Fireplace. Shawnzy Tiling, ceramics, marble 1 03-02-2011 09:38 AM
First time tiling! (and its a fireplace) Shawnzy Tiling, ceramics, marble 6 01-18-2011 03:47 PM
Tiling Fireplace Bper Building & Construction 1 12-06-2008 12:02 PM
tiling a fireplace Jack Hass Remodeling 2 07-28-2008 09:04 AM
