Re-gout Over Re-grout - Flooring - DIY Chatroom Home Improvement Forum
Old 12-25-2010, 01:47 PM   #1
Re-gout over re-grout
its new grout down about a year and sealed about 3 coats. But noticed that the grout is not enought
that was put down in the kitchen. And want to add more to make it more level with the tile and easier to clean . Help
eazis1952 is offline   Reply With Quote
Old 12-31-2010, 07:09 PM   #2
Not sure I understand the issue. Are you saying that the existing grout isn't close enough to the surface of the tile? In other words, the grout lines are too deep?
If so, not to worry. You can lightly grind off the layer of sealant and re-apply all the grout you want. Depending on the quality of the sealant used, you may not even have to worry about the grinding step.
BigMan926 is offline   Reply With Quote
Old 01-01-2011, 01:03 PM   #3
Hand saw out some of the old grout... they make a little tool for this. Vacuum up all dust and old grout. Re-grout with sanded grout to the heigth you want.
mrs. c is offline   Reply With Quote
Can bad grout job be salvaged? wlsmith Tiling, ceramics, marble 22 11-14-2010 06:31 AM
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 07:07 PM
Repairing missing grout in shower stall CLM Tiling, ceramics, marble 14 10-03-2010 10:08 PM
Removing grout from top of ceramic tiles markdrum1 Tiling, ceramics, marble 3 09-28-2010 09:38 AM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 10:59 PM
