#1 |
Ranch base moulding in place of reducer
I have a tile floor transitioning into a wood floor. The tile is 5/8 high and I was going to use a reducer, but have found that it is much cheaper to buy ranch base moulding and it has almost the identical shape as the reducer. Is there any reason not to use the moulding in place of the reducer.
#2 |
This should work just fine. As long as your client is ok with it, I don't see any reason why not.
| The Following User Says Thank You to RhodesHardwood For This Useful Post: | PaulSDC (06-18-2012) |
#3 |
Only problum may be is ranch is soft pine and most reducers are hardwood and ranch will have a rounded edge on the high side.
| The Following User Says Thank You to joecaption For This Useful Post: | PaulSDC (06-18-2012) |
#4 |
Stairguy
It should be made from the same wood as you floor. Buy square stock and rip a bevel on the tablesaw
#5 |
I use oak in my house to go from floor to tile. It was cut on a table saw to the size needed. Oak base will work. I have both pine and oak colonial in my house. Oak is stained and pine is painted white.
| Display Modes | |
| Fix For ELM Shower Base Drain Leaks | MarkSilber | Plumbing | 0 | 02-14-2012 10:02 AM |
| Crown Moulding Paint Peeling | ryanb4614 | Painting | 6 | 01-23-2012 10:15 AM |
| Installing a Sterling shower receptor in a mortar base | repoocaj | Plumbing | 2 | 11-19-2011 08:52 AM |
| How to tile around a Pre fab shower base | geoffthemonk | Building & Construction | 1 | 11-07-2009 10:10 AM |
| Best place for moulding? Bulk pricing | troyce1 | Building & Construction | 1 | 01-14-2009 06:31 PM |
