Ran Out Of Laminate Flooring. - Flooring - DIY Chatroom Home Improvement Forum
Old 07-12-2012, 11:22 PM   #1
Rewards Points: 262
Ran out of laminate flooring.
OK I'll admit it. I made a newbie mistake of wastinr too much material for my project. Unfortunately, Pergo discontinued the material. I had bought what I thought to be enough Pergo Presto Salem Oak to cover my kitchen and living room. I was wasting too much in the beginning and by the time I figured out how to plan it better I had left myself short. Does Anybody know where I can find discontinued laminate flooring?
Jim F is offline   Reply With Quote
Old 07-13-2012, 03:23 PM   #2
Rewards Points: 150
Unfortunately, this appears to have been an HD exclusive design. I checked the store and warehouse inventory (don't ask) for NE and NY/NJ and came up with nothing. You might road trip to a bunch of HD is the area to see if they may have a damaged or partial box.
goosebarry is offline   Reply With Quote
Old 07-13-2012, 04:16 PM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
How did you end up with more wast then expected?.... Mind me asking?
JetSwet is offline   Reply With Quote
Old 07-13-2012, 10:53 PM   #4
Rewards Points: 262
The biggest mistake I made was to just cut off the tongue on my starter piece on alternate rows. It is sort of hard to explain. Mostly I did not realize that I could use a piece as short as 12 inches on the beginning and end. I was winding up either a few inches short or with too much waste on the end piece. I finally figured out that I could cut 12-13 inches of the tongue side of my alternate starter peice and add that to the end of the next row. I made other mistakes too plus the intricate cuts resulted on more waste than expected.
I trusted the flooring guy at Home Depot to estimate the number of boxes I would need so it is possible he underestimated my needs. To add to the problem, this is an extension of the kitchen renovation project I started last year and I'm just now getting around to finishing the living room side of it. My wife wanted the entire first floor of the main house done in the same flooring but I just had too many other things pop up that took me away from the floor. So this floor is now discontinued.
My wife has an idea where I could frame around the hearth of the fireplace and the final rows with a richer, more dramatic color of laminate and that might work. Also Lumber Liquidators has a very close match in a brand called Dream Home so I am going down there soon to check it out. I doubt the tongue and grooves will line up. If not I will have to incorperate a transitional strip.
I was just hoping that someone here would know of an overstock resource I have not yet found on the web or maybe even have some Salem Oak left over from a job.
Old 07-16-2012, 04:56 PM   #5
Rewards Points: 150
Another option is to check Lowe's. Prego has some exclusive patterns with them as well. Pergo 7-5/8"W x 47-3/4"L Yorkshire Oak Laminate Flooring is the same form factor and appears to be just a little lighter.
The Following User Says Thank You to goosebarry For This Useful Post:
Jim F (07-16-2012)
Old 07-16-2012, 05:06 PM   #6
Rewards Points: 12,794
Check on Craigs List under materials.
Go to your local Restore, it's where people can donate building items to raise money fo Habitate for Humanity.
Also just Google the maker and color your looking for as a key word search. Lot's of times something will pop up worth looking into.
Jim F (07-16-2012)
Old 07-18-2012, 09:47 AM   #7
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
That name sounds awfully familiar. I would call around to different home depot's and see if they have any left. I am almost positive I have seen that recently.
CoconutPete is offline   Reply With Quote
Old 07-19-2012, 11:35 PM   #8
Rewards Points: 262
Not in any of our local stores. If you happen to see it in your local store, let me know the store number and location. CT is not that far and it would be a good excuse for a road trip.
Old 07-20-2012, 08:17 AM   #9
Can Home Depot do a nationwide inventory search and ship it to you if they find it?
Pianolady is offline   Reply With Quote
Old 07-20-2012, 08:26 AM   #10
Craigslist in Idaho
For sale 20 cases of Pergo Flooring.
Pergo Presto Salem Oak 8mm Thick x 7-5/8 in. Wide x 47-1/2 in. Length Laminate Flooring (20.1 sq. ft./case)
Hopefully this won't get tagged as spam, but I think this is your flooring. Maybe you can pay them to ship it to you.
The Following User Says Thank You to Pianolady For This Useful Post:
Jim F (07-20-2012)
Old 07-20-2012, 06:32 PM   #11
Rewards Points: 262
Wow, thanks a lot Piano Lady! I actually did check out the local craig's list and came up empty. Even better news for me though is that I went to my local HD today and they searched their regional inventories and found 4 cases in their Painted Post store. Painted Post is near Corning in New York. They had done this for me a week ago with 2 other stores but when I called the stores, they no longer had the cases. I bought the 4 cases they have at Painted Post unseen just to make sure they hold them. They can't transfer them up to the local store so I must drive down to get it, 2 hours away. So, I'm thinking a family trip to the Corning Glass museum is in order.
Old 10-29-2012, 10:04 AM   #12
Pergo presto laminate flooring salem oak ph 4700
Did you ever find any? I need a couple of boxes as well. Thanks.
Tip71 is offline   Reply With Quote
Old 11-15-2012, 04:36 PM   #13
Pergo Salem Oak
Pergo outlet store shows a few cartons of Salem Oak availible
http://www.pergoonline.com/salem-oak/
paulchev is offline   Reply With Quote
Old 11-15-2012, 11:47 PM   #14
found this if anyone still needs any. they have 480 sq ft still in the boxes.
http://columbus.craigslist.org/mat/3410600178.html
http://portland.craigslist.org/clc/mat/3400530680.html
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Laminate flooring and such for kitchen christineka Flooring 5 01-04-2011 08:08 AM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
