Ran Into Cinder Blocks When Running Nail-down Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 02-10-2012, 11:37 AM   #1
Ran into cinder blocks when running nail-down flooring
I'm nailing down ~3/4" stranded bamboo on top of the original 3/8" hardwood. 700 square feet, everything is great (other than the squeaks!!), until I get to the last 8 square feet. There is a fireplace in the basement, and on the main floor, the top of the cinder block from the fire place is at floor level. The top is 1/4" under the level of the 3/8" hardwood, with no moisture issues whatsoever.
Any suggestions on how to handle this since I can't nail into the flooring? Self-leveling compound and glue-down the bamboo? What would go between the bamboo and self-leveler? 1/4" subfloor onto the cinder blocks and then glue-down the bamboo? ANYTHING else???
Thanks!
Oh, I found the cinder block after pulling up carpeting.
joeh is offline   Reply With Quote
Cinder blocks not intersecting at corner of foundation. OK? mjjstang Building & Construction 0 07-29-2011 09:37 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 07:06 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
what type of nail gun for bamboo flooring? matchley Flooring 4 12-26-2007 03:47 PM
