Raising Sunken Living Room - Flooring - DIY Chatroom Home Improvement Forum
Old 09-26-2010, 06:56 PM   #1
raising sunken living room
I looking to build up my sunken living room. I want to lay down porcelain tile for flooring. Currently is a cement slab. Can this be done without filling in with cement?
MarcLich is offline   Reply With Quote
Old 09-26-2010, 07:02 PM   #2
Not to be a dick but its concrete, not cement. Cement is just portland cement which is a portion of concrete. Concrete is portland cement, sand, aggregate and sometimes additives depending on the mix (whether it be accelerants, fly ash, etc.) Now that I am done with my lesson
Why not build it up with framing? It cheaper, easier etc. Its also lighter and if you put a large amount of weight on the an existing slab it may cause it to settle. Just a thought.
Edited......Please dont take my comment about you saying cement as putting you down. Its just when you are talking to people you want to make sure are using the correct terms.
wnabcptrNH is offline   Reply With Quote
Old 09-26-2010, 08:41 PM   #3
If I knew what I was talking about I wouldnt have to post here. No offense taken. What would you cover the frame with? Would plywood be stable enough to handle the mortor and tile.
Old 09-26-2010, 08:51 PM   #4
fill it in with framing, install 3/4" plywood and then start tiling.
I personally dont like installing tile on plywood. I like using cement board on top of the plywood as the adhesion surface for the tile.
Old 09-26-2010, 08:53 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
3/4 " plywood isn't thick enough for tile.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 09-26-2010, 08:58 PM   #6
Please show me where it says that in the code or engineering book. I have built many houses and installed tile over 3/4 plywood and not had issues. I can see you were a flooring installer for years.
You say 3/4" plywood isnt thick enough. Why not make a suggestion instead of just saying it wont work???/
Old 09-26-2010, 09:06 PM   #7
Rewards Points: 82
Either Jaz or Bud Cline will be along. They will give you the details from the TCNA handbook.
Old 09-27-2010, 07:28 AM   #8
I read somewhere that 1 inch thick plywood should be used. Does that sound about right?
Old 09-27-2010, 08:29 AM   #9
Rewards Points: 82
I am not a tile guy. But I believe 2 layers is better than one and it needs to be 1 1/8 to 1 1/4 thick. And CBU adds no structural strength. But if one of the tile guys says something different, take their word for it.
How do you remove a wood stove and bricks from living room? SimpleJack Remodeling 13 08-28-2011 01:26 PM
need new Living room layout, very confused fox_forma Interior Decorating 14 03-17-2010 08:26 AM
trailer in my living room (must read) wengang1 Remodeling 0 01-19-2010 03:30 PM
Adding A Ceiling Fan To Living Room jte1130 Electrical 1 05-28-2008 03:05 PM
wooden balcony in living room Lorac Building & Construction 1 07-24-2004 03:33 PM
