Old 11-26-2012, 12:55 PM   #1
Lightbulb
Raising & replacing stair treads
Just wanted to bounce an idea off everyone.
I am replacing two straight stair treads. The current treads were flush with the risers and not the prettiest things once I got the carpet off. I need to raise them a bit, too, since the floor above was tiled (and thus raised from original) and I will be adding hardwood below (leaving that floor higher than the existing carpeting).
My idea is to cover the risers and existing tread fronts (painted 1/4-in plywood) and install hardwood treads (hickory) on top of the existing pine treads. Right now, there's some difference between the stair rise but doing that reduces the differences to ~1/4-in stair-to-stair.
I can get under them (full basement) so I was going to use wood screws from below. Thinking countersunk 1-1/2 #8 screws, six per tread.
To keep them from being squeaky, I was going to put 30# tar paper between the old and new treads.
My reasoning:
- someone can replace the treads at a later date without a bunch of hassle
- beating the old treads out looks too much like work (and unnecessary)
Thoughts?
zakany is offline   Reply With Quote
Old 11-28-2012, 12:26 PM   #2
Well, I followed the above except that I used 1-3/4 #8 wood screws.
The end result wasn't bad.
Old 11-28-2012, 05:24 PM   #3
STAFF
BigJim's Avatar
Sorry I didn't catch your thread, sounds like you already have everything going your way, got any pictures you might want to share?
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 11-28-2012, 10:27 PM   #4
Pictures? Sure. Remember that the nasty carpet is getting replaced with solid hickory!
Old 11-28-2012, 11:51 PM   #5
STAFF
BigJim's Avatar
That is a heck of a difference, I would be happy with that, it looks great. Thanks for the pictures.
Jim
Old 11-29-2012, 11:51 AM   #6
I'll look better after I paint the walls, refinish the trim, and install the flooring.
nosing on stair treads Clutchcargo Building & Construction 5 05-13-2012 04:15 PM
Is this plan for finishing new red oak stair treads OK? Jayco Flooring 1 01-13-2012 08:06 PM
What is the correct way to redo stair treads. John/Suz Flooring 5 10-13-2011 09:11 AM
Leveling Stair Treads JDScalf Carpentry 16 09-11-2011 08:57 AM
sanding pine stair treads. Need adivce. Mike in Arkansas Flooring 2 07-20-2009 11:01 AM
