-   -   Raising & replacing stair treads (http://www.diychatroom.com/f5/raising-replacing-stair-treads-164774/)
zakany 11-26-2012 11:55 AM
Just wanted to bounce an idea off everyone.
I am replacing two straight stair treads. The current treads were flush with the risers :huh: and not the prettiest things once I got the carpet off. I need to raise them a bit, too, since the floor above was tiled (and thus raised from original) and I will be adding hardwood below (leaving that floor higher than the existing carpeting).
My idea is to cover the risers and existing tread fronts (painted 1/4-in plywood) and install hardwood treads (hickory) on top of the existing pine treads. Right now, there's some difference between the stair rise but doing that reduces the differences to ~1/4-in stair-to-stair.
I can get under them (full basement) so I was going to use wood screws from below. Thinking countersunk 1-1/2 #8 screws, six per tread.
To keep them from being squeaky, I was going to put 30# tar paper between the old and new treads.
My reasoning:
- someone can replace the treads at a later date without a bunch of hassle
- beating the old treads out looks too much like work (and unnecessary)
Thoughts?
zakany 11-28-2012 11:26 AM
Well, I followed the above except that I used 1-3/4 #8 wood screws.
The end result wasn't bad.
BigJim 11-28-2012 04:24 PM
Sorry I didn't catch your thread, sounds like you already have everything going your way, got any pictures you might want to share?
zakany 11-28-2012 09:27 PM
Pictures? Sure. Remember that the nasty carpet is getting replaced with solid hickory!
http://1.bp.blogspot.com/-XYGvIw7ADi...0/P1000924.JPG
http://3.bp.blogspot.com/-Oa8vTcpsIw...0/P1000928.JPG
BigJim 11-28-2012 10:51 PM
That is a heck of a difference, I would be happy with that, it looks great. Thanks for the pictures.
zakany 11-29-2012 10:51 AM
I'll look better after I paint the walls, refinish the trim, and install the flooring.
