Raising Level Of Floor With OSB - Flooring - DIY Chatroom Home Improvement Forum
Old 11-25-2011, 03:31 PM   #1
Murdy's Avatar
Rewards Points: 37
Raising level of floor with OSB
We are remodeling our kitchen, and will put down ceramic tile eventually. The kitchen is a bit lower than that floors in the rest of the house (we live on a slab -- apparently, the rest of the house has some sort of underlayment). I'd like to put down 1/2 inch OSB under the tile. I have a hammer drill, so I intend to screw the OSB to the concrete slab.
- How should I space the scews?
- How substantial of a screw should I use?
- Should I use some sort of adhesive as well?
-(part of the area had vinyl tile held down with some black, sticky stuff (called cut out, I think??), if I use adhesive, do I need to get this completely off, I hoped to just scrape it down and put the OSB over it)
I will appreciate all advice.
Murdy is offline   Reply With Quote
Old 11-25-2011, 04:09 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
I wouldn't put OSB on a slab. It will fall apart. And I wouldn't put ceramic on OSB on concrete.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-25-2011, 05:01 PM   #3
Murdy's Avatar
Rewards Points: 37
I've been doing a little reearch since I posted the question, and figured out OSB isn't the right thing to use here. Read some negative stuff about plywood too. What would be the right thing to use here?
Old 11-25-2011, 05:52 PM   #4
Rewards Points: 82
Thinset.....
Old 11-25-2011, 05:59 PM   #5
Murdy's Avatar
Rewards Points: 37
Thinset direct to the slab? Any way to raise the level?
Old 11-25-2011, 06:24 PM   #6
Rewards Points: 150
You could use kerdi xl.
OhioHomeDoctor is offline   Reply With Quote
Old 11-25-2011, 10:58 PM   #7
www.schluter.com/Schluter-DITRA-XL.aspx is what you need. This is the proper way to get the height you need. Use modified mortar under the Ditra and unmodified mortar to set the tile.
plowboy is offline   Reply With Quote
raising floor level shrinkinfoot Flooring 8 10-01-2011 02:35 PM
How 'level' is level? BOUTYM Flooring 2 09-04-2011 05:30 PM
Raising the level of concrete floor chandan.cogni Flooring 3 12-30-2010 06:37 AM
Raising property level with existing lawn earthad1 Landscaping & Lawn Care 9 03-29-2010 01:53 PM
Raising The Ceilings propain Building & Construction 2 06-28-2006 05:33 PM
