Raising The Level Of Concrete Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 12-30-2010, 03:47 AM   #1
Raising the level of concrete floor
Hi,
My house is almost 25 years old, it is built out of concrete and bricks. It is a two story building.The floor is plastered from cement and the problem which I am facing is that level of the floor has gone down as compared to the road outside. As it is an old house, so it was constructed before the construction of roads. Now my house is almost half a meter lower than the level of road.
Is there any way out to raise the level of base without reconstructing the whole building. Note that if the level of the floor will be raised using concrete coating then the distance between the floor and the ceiling will reduce, which I am not in favor of doing.
Any suggestion is very much awaited.
Chandan Sinha
chandan.cogni is offline   Reply With Quote
Old 12-30-2010, 04:02 AM   #2
Stay-at-home GC
I'm assuming the .5 meter (approximately 1.5 feet)! is the fall from the road to the entrance of a garage? How far are you from the road?
CplDevilDog is offline   Reply With Quote
Old 12-30-2010, 06:20 AM   #3
Raising the level of concrete floor: Contd...
The road is running 1 meter away from my house.
Old 12-30-2010, 06:37 AM   #4
Stay-at-home GC
Wow! That's quite a drop-off. I assumed we were discussing a home in the country that had the road at the end of the driveway regraded, but that doesn't seem to be the case. Pictures would be helpful to avoid any confusion.
getting rid of carpet > concrete floor > polish or stain? johnlvs2run Flooring 24 11-23-2010 10:31 PM
Basement concrete floor repair estimate ControlTech Building & Construction 1 04-10-2010 07:28 AM
Basement water meter below floor level redfox1 Plumbing 5 12-10-2008 08:20 PM
Join Wood Cyc Ramp to Concrete Floor Bigboots Building & Construction 3 11-27-2007 09:52 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
