Raise The Height Of My Sub-floor In Prep For Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 03:56 PM   #1
Raise the height of my sub-floor in prep for laminate flooring
I'm looking for a little advice. My subfloor is 3/4" tongue & groove plywood. I need to raise the subfloor surface 1/4" so that the surface of the new Armstrong laminate flooring I purchased matches the height of my kitchen tile floor. I have read that 1/4" birch plywood should be applied over my existing subfloor. QUESTION: Do I really need to spend $20 a pop for 25 sheets; or is there a cheeper and adaquate grade of material available for this? Thanks in advance for any advise.
chrisrod is offline   Reply With Quote
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 06:24 PM
Allure flooring and prep work bstreyle Flooring 1 04-12-2010 03:43 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
Need to raise counter height over existing kitchen cabinets Eric Adams Carpentry 6 07-12-2009 01:38 PM
